03-12-2017, 09:05 PM | #1 |
3 spoke comfort grip steering wheel
I've looked thru the site I'm trying to find out if an 3 spoke comfort steering wheel from a Camaro will fit on a 1965 chevy truck with an standard colum
I've found a lot of 67-72 trucks with them .. any help or other ideas for a steering wheel Thanks Bill |
03-13-2017, 10:07 AM | #2 |
Re: 3 spoke comfort grip steering wheel
Yes , you can put the three spoke wheels on but you need to use the 1967-1968 wood wheel hub from a Camaro ,Chevelle Impala. Its the correct diameter. I put a 2 spoke wood wheel on this 1966 using a three spoke hub. The 69 up hub is too big in Diameter. Then you need to add the turn signal cancelling cam to the bottom of the hub from your current steering wheel.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
03-13-2017, 09:20 PM | #3 |
Thanks for the info now I can get on with buying the wheel and get something done
03-14-2017, 06:11 PM | #4 |
Chevy addict
Sweet John |
03-14-2017, 07:31 PM | #5 |
Moderator
I'd love to put that wheel in my 65 Impala!!
