11-07-2016, 09:19 PM | #1 |
Vineager rust remover
I believe little of what I see or hear anymore HOWEVER I watched several youtube videos about using diluted vinegar for surface rust removal---I took the chance on a $2 a gallon vinegar and------IT WORKED!!!!!! I could not believe it! soak the panel--covered with paper towels---resoaked and covered with plastic for 3 hours The rust came of with a scotchbrite just as if it was fresh stamped out at the factory!!!!!! TRY IT!!!!!!! IT WORKS!!!!!!
11-07-2016, 09:25 PM | #2 |
Re: Vineager rust remover
OH---and be sure to neutralize the vinegar with 1qt water and 2 tablespoons baking soda throughly dry pre cleano then prime
11-07-2016, 09:28 PM | #3 |
Moderator
Pool acid (muriatic) works even better
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-08-2016, 07:53 AM | #4 |
That muriatic is some nasty stuff, though. Also costs more. What I want to know is where are the pictures?
11-08-2016, 08:35 PM | #5 |
5 gallons of molasses (feed store) in the biggest garbage can you can find works for big stuff and lasts for more than a year. A gallon in a 5 gallon bucket is good for smaller stuff. Strange little animals grow in it and it smells odd so bleach helps.
It also removes quite a bit of paint over time. Once derusted, rinse and scrub the parts and coat w/ diluted phosphoric acid (paint section of the hardware/home store) in a spray bottle to stop flash rust. |
11-08-2016, 11:38 PM | #6 |
BlahBlahBlah
You can buy a gallon of vinegar at the dollar store ... wait for it ... for a buck! Drop your cruddy nuts and bolts in there, give it a shake once in awhile when you walk past it in your shop.
A couple of days in pour it in to a colander, check the progress. If not good enough, grab your nuts (and bolts heh) put em back in the vinegar bottle, pour the strained vinegar back in the bottle and let it go for a little longer. |
11-09-2016, 06:19 AM | #7 |
The first use of vinegar, other than putting on greens, I heard of was wipe down painted aluminum building products (siding, gutters, etc) as a prep before successfully re-painting. I never tried it to eat rust. I'll have to try it. I have used acid-based products to make rusty metal look fresh again...even into the pits, looks sand blasted without the coarse texture. Isn't vinegar also used as a weed killer?
11-10-2016, 07:38 PM | #8 |
Who Me?
A friend of mine used this a lot for small part, nuts and bolts. He always neutralized the parts with backing soda and water. Old rusty bolts look like brand new.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
11-11-2016, 05:38 PM | #9 |
Did this with fistilled vinegar and it was good. On my gas tank. Got about half the rust off (tank is REALLY RUSTY)
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
11-17-2016, 12:05 AM | #10 |
HERE.......Somewhere
I used Coca-Cola and aluminum foil balled up and used it to remove rust
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
11-17-2016, 09:22 PM | #11 |
12-01-2016, 11:28 PM | #12 |
Cool
12-02-2016, 07:47 AM | #13 |
So I assume this is just regular white vinegar you all are using correct ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
12-02-2016, 09:00 AM | #14 |
i use all the time at when they have a piston frozen in a block .... i just keep topping off the cylinder for about a week or two and pop out the piston w/o any problems ...
dont want to hear excuses, i want to hear solution(s) |
12-03-2016, 09:01 PM | #15 | |
"Tail Gate Best Seat In House"
https://www.youtube.com/watch?v=y4yYF8gSHdA
When you learn a thing a day you store up smart. |
12-06-2016, 06:53 PM | #16 |
Refresher---yes regular white vinegar I used it straight REMEMBER TO DILUTE/NUETRALISE with baking soda mixed into plain tap water dry then prime-----
03-15-2018, 11:07 PM | #17 |
Countdown Survivor
And we're eating/drinking that stuff lol?
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
03-15-2018, 11:21 PM | #18 |
Beets are great for rust removal too. Just had a great beet salad in Fl. last week.
03-16-2018, 07:05 AM | #19 |
Mmm... vinegar on beets. I like them tops and all. I'm glad you brought this thread back. I want to start cleaning up and preserving some stuff.
03-16-2018, 01:21 PM | #20 |
I've used vinegar to remove rust from the inside of gas tanks with great results. I've used it for old Jerry cans, old boat gas tanks, and motorcycle gas tanks. I dilute the vinegar a bit with water and pour it in. I then add a handful of bb's. Then shake it up and let it sit and put it on different sides over a course of a few days, shaking it up before switching sides. After a few days pour it out through a strainer and it should be good as new. Then use a gas tank paint to coat the inside.
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
03-17-2018, 11:12 PM | #21 |
I put this mix thru a test and it works great I put some of my old gm truck trim in my tub and filled it with the vinegar and baking soda my tub came clean but the mixture dissolved my trim completely away
4x4k30 if trouble was money i would have plenty Last edited by 4x4k30; 03-22-2018 at 04:42 AM. |
03-18-2018, 09:33 AM | #22 |
What trim was it?
Thread Tools | |
Display Modes | |
