04-18-2018, 05:36 PM | #1 |
warn hub bolts
Brand new warn hubs on my dana 44. why do the hub bolts break? Just fixed one side with 3 broke, one is broke on the other side. Might have broke while removing. Had anti-seize on them. So why do they break? when i pull the other side i gonna make sure they are not bottoming out thread wise. I only locked them in twice. Maybe just cheap warn ? around $100.
1961 chevy K10 my build is------------61K10 build |
04-18-2018, 06:36 PM | #2 |
Re: warn hub bolts
warn hubs for years now have gone cheep / pot metal crap if you ask me .
go get some old school spicers and clean them up . or new yukon hubs . yukon hubs are the best of the dana 44 and dana 60 spicer hubs designs all in 1 hub . and if the yukon or spicer ever failed they will fail locked unlike warn goes open .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-18-2018, 06:53 PM | #3 | |
Re: warn hub bolts
What year dana 44? what warn part # ?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
04-19-2018, 01:10 PM | #4 |
Re: warn hub bolts
GSP7--org 61 closed knuckle (added disc and open knuckle spindles/hubs) warn 20990 lock-outs. 1/2t of course. seams I am not the only one with this problem doing some searching on the net.
04-19-2018, 03:25 PM | #5 |
Re: warn hub bolts
I have those same hubs. 30 years old. Never had those little skinny Allen heads break
04-19-2018, 08:23 PM | #6 |
Re: warn hub bolts
30 year old units are better quality than new crap they sell us now.
04-19-2018, 10:42 PM | #7 |
Re: warn hub bolts
I like the yukon's but not the price. They look like my org spicer ones on my old hubs.
04-21-2018, 10:52 PM | #8 |
Re: warn hub bolts
I did notice when I put my new ones on that the bolts felt "flimsy". As if they hadnt been hardened. Looked a lot like chintzy IKEA furniture hardware. Had forgotten that I wanted to replace them till now.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-22-2018, 08:20 AM | #9 |
Re: warn hub bolts
I agree on the bolts. I have a new set of warns in the box for at least 9 yrs and noticed made in China sticker.
Reluctant to use them, haven't had to yet, they definitely look like a lower quality than what I was used to, and I always used warn. Maybe ARP will come out with a bolt kit, the supplied ones look and feel like sheer bolts to me. I know you don't mash them down, but they seem like they'd break at 10lbs of torque. C,Mon Warn, start up your American plant again |
04-22-2018, 11:11 AM | #10 |
Re: warn hub bolts
I refurbished my 30 year old warns last year and repainted the recessed lettering and dial slots etc
04-22-2018, 12:23 PM | #11 |
Re: warn hub bolts
I did replace the bolts with some (8-18?) stainless from the bolt depot.
04-23-2018, 08:06 PM | #12 | |
Re: warn hub bolts
Did those (and Im not trying to come off like a know it all) "feel" any better? I know sometimes stainless can be pretty soft.... unless you have to drill it out in an emergency. I remember vividly installing those screws and thinking I was gonna snap one just installing them. Ended up running a bottom tap into the holes and using never seize on them as well. Still didn't get a good feeling about them.
04-24-2018, 12:42 PM | #13 |
Re: warn hub bolts
Chris--I know what you mean about the feel when installing. I thank one or more of mine broke when removing. the stainless felt better for sure. They didn't have any long enough in 316 stainless. They were only .21 a piece. I guess we will see if they are any better than stock ones. They are breaking right as they inner the lockout.
05-14-2018, 09:19 PM | #14 |
Re: warn hub bolts
Kimble that's the same thing I put on mine and so far haven't had any issues.....
1964 BBC 402 4x4 |
05-15-2018, 12:39 PM | #15 |
Re: warn hub bolts
Randy you might of got a good set or i got a bad set. Who knows nowadays. keep an eye on yours just in case.
05-18-2018, 05:59 PM | #16 |
Re: warn hub bolts
10-4
1964 BBC 402 4x4 |
