12-11-2002, 10:07 PM | #1 |
Collector of rusty Items
travel limit devices
I am putting air bags on my 4x4 so I can haul lots of firewood and let them down for a softer ride. I need to limit the travel so the bags don't pop.
I see a lot of guys use nylon straps.. I have a hard time with that idea. it just doesn't seem strong enough. I am thinking about chain, but it seems like there might be a lot of shock and might bust something. If I hit a bumb and the truck bounces up, it could snap pretty hard. Any good ideas? Thanks
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
12-13-2002, 02:42 PM | #2 |
You can buy limiting staps that prevent the axle from dropping down to far. They are nylon, but they arn't going to break. They are big like a tow strap. Don't get any that don't look like you could pull a vehical with'em. I would much rather have these straps than a chain. And to limit travel upwards you just need to have the correct size bump-stops.
I need all the help I can get. |
12-21-2002, 10:01 AM | #3 |
Limit straps!
