07-21-2015, 09:05 PM | #1 |
K5 Factory Jack
Can someone help out and post some pictures of the proper jack and accessories for 68 - 72 Blazer, and where they are stowed away? Thanks
07-21-2015, 10:37 PM | #2 |
Re: K5 Factory Jack
It is the same jack as the pickups. Go to the top of the page in the google box and click 67-72 Chevy trucks.com Put in Jack assy . If you want one that is similar . Ford and Chevy late model trucks look almost identical otherwise the forum has quite a few for sale.
07-21-2015, 11:04 PM | #3 |
I'm trying....
Re: K5 Factory Jack
Here is the jack set up with rear seat equipment. If no rear seat, the spare tire and jack would move forward behind the driver's seat, but basically in the same orientation. The lug wrench and jack handle would be behind the driver's seat as pictured, though the double hook at the end of the spring should engage the jack handle. I have been working on a reproduction of the Jacking Instructions decal. You can see the arrangement in the illustration.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
07-22-2015, 08:03 AM | #4 |
Re: K5 Factory Jack
Thanks Iron Canine, put me on your list for the new decal. Jack
07-23-2015, 09:17 AM | #5 |
Re: K5 Factory Jack
Great info. Put me on the list for a decal also, Thanks Tom
10-07-2016, 04:17 PM | #6 |
Re: K5 Factory Jack
Howdy, do you have any of these decals?
Thanks, Matthew |
05-04-2017, 01:35 AM | #7 |
Re: K5 Factory Jack
Does anyone have a proper working jack and lug wrench available for a 72 Blazer?
05-04-2017, 02:19 PM | #8 |
Re: K5 Factory Jack
I believe its the same as a truck. Look on the truck classified side. You may get reprimanded for a wtb ad when you're not blue.......
05-05-2017, 02:03 AM | #9 |
Re: K5 Factory Jack
I will look there, thank you for the tip and advice which I will heed.
05-09-2017, 05:05 PM | #10 |
Re: K5 Factory Jack
anyone have a jack or the jack holder or tools for sale for a 72 blazer thanks
