04-06-2016, 05:11 PM | #1 |
350 swap
by using the stock 350 rear dump exhaust manifold do these run into clearance issues also with putting 350 in AD
04-06-2016, 07:48 PM | #2 |
Re: 350 swap
Might want to post up more about what your suspension set up is. Guessing stock, but dont' want to assume.
55.1 GMC Suburban Hydramatic |
04-06-2016, 08:01 PM | #3 |
Re: 350 swap
This has been covered a ton, a search will get you days of reading....
04-06-2016, 08:47 PM | #4 |
Re: 350 swap
04-06-2016, 08:49 PM | #5 |
Re: 350 swap
Every body talks about ram horns and such just haven't read anything about stock rear dumps thought it was simple question
Posted via Mobile Device |
04-06-2016, 11:40 PM | #6 |
Re: 350 swap
there's clutch linkage and stuff. need to know what you're working with to give a decent answer.
04-07-2016, 01:11 PM | #7 |
Re: 350 swap
to add to tmobile: usually you have steering box and brake pedal in that area
center dump rams horns or block hugger avoid all these areas
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-07-2016, 04:54 PM | #8 |
Re: 350 swap
Thank you OGRE
