06-11-2018, 08:03 PM | #1 |
Which intake 7.4L Vortec?
What options for an intake do I have if I want to run a carb, or aftermarket fuel injection on my 7.4L Vortec? I did not get the computer or the wiring harness, or the throttle body for the original set up, so I figured I would either carb it, or maybe install an aftermarket fuel injection set up.
06-15-2018, 08:14 AM | #2 |
Re: Which intake 7.4L Vortec?
Put in a bunch of filters over at Summit
if its a Vortec 7.4 its a mark VI, the filters i have are for carburated dual plane intakes. You didn't list your cyl head port configuration, so you can narrow it down some more. (or less by deselecting things). I'm sure others will chime in, but it'd be easier to advise if we knew your goals (racing, towing, 4x4 etc.) |
06-15-2018, 04:40 PM | #3 | |
06-19-2018, 01:32 AM | #4 |
Edelbrock, and Whipple each make a kit, belt driven any where from 6 to 14 pounds manifold pressure, depends on pulleys, exhaust restriction, air temp, etc.
