08-26-2018, 09:44 AM | #1 |
Not what's recommended?
I bought an edelbrock 7116 intake maifold at a swap meet for my vortec heads. After bringing it home thinking everything is just gonna transfer over from the set up I have, found out I can't use my carb. The carb is a 600 performer and they recommend a 750 performer. Think I could get away with the 600 or do I need to use the 750?
08-26-2018, 09:50 AM | #2 |
Re: Not what's recommended?
Yes you can use it. As long as it will bolt on of course.....
08-26-2018, 12:56 PM | #3 |
carb size has nothing much to do with it . . . . its the base plate pattern that make it a bolt on or conversion parts required swap .
cfm of the carb comes in to play with rpm's and hp levels .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-26-2018, 01:28 PM | #4 |
The 600 will be fine, if anything it will work better than the 750 on a stock engine.
08-26-2018, 11:58 PM | #5 |
60-66 Nut
The Edelbrock 7116 is a Performer RPM for the Vortec heads and it has a square bore carb flange. Any square bore carb will bolt up. I would suggest a 600cfm carb with a stock to mild built 350.
08-28-2018, 03:27 PM | #6 |
driving is in my blood
Who exactly is "they" recommending a 750cfm carb?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
08-29-2018, 03:24 AM | #7 | |
Capt. has been here a while and everything he has recommended is pretty much spot on. There are those here that won't throw you wrong. You will get to know who they are. Its a great place to figure these old trucks out. Many a time the folks here have saved me a ton of bucks with the correct advise. Not to mention steering me in the right direction. I think the other recommendation you have got is due in part that the old Rochester carbs could do 750 cfm. |
