08-28-2013, 11:22 AM | #151 | |
Re: Best "Rake/Stance" for a Hot Rodded 60-66 C10?
Glos55 posted more pictures of it here: http://67-72chevytrucks.com/vboard/s...d.php?t=581542 |
08-28-2013, 09:55 PM | #152 | |
Rollin' Old Skool
Posted via Mobile Device Posted via Mobile Device
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
08-28-2013, 10:01 PM | #153 | ||
But Found Her 25yrs Later!
08-29-2013, 03:49 PM | #154 |
I kept the 66 lwb stock height. Still has a lower front rake and like "tenni126" say's No matter what load I put back there all she ever does is sit level!
08-30-2013, 05:52 PM | #155 |
Still holding a 2-5 degree rake just lower.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-30-2013, 07:42 PM | #156 |
Here's mine. A slight rake. Any lower in the back and I have clearance issues.
08-30-2013, 09:52 PM | #157 |
^ Rob-
I really, really, really like your truck! Sits great, and I really dig the color combo.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
08-30-2013, 10:21 PM | #158 |
This some older pictures of my '64. I've done a lot more suspension work since then, and I don't have any pics of the latest configuration, but will have some as soon as I get it back on it's wheels.
Since these pictures were taken, we have Z'd the front of the chassis up 2" and forward 1" to center the wheels in the wheel openings. The rear is coming down about another 1.5-2.0 inches. I want a hot rod rake, so the rear will still be higher than the front. It's a little too much right now.
08-31-2013, 02:56 AM | #159 |
X2 Rob and why I do I will post a pic of mine..Vernski
08-31-2013, 04:53 AM | #160 |
Brutus has a pretty good rake-
08-31-2013, 02:31 PM | #161 | |
There is something wrong with the front bumper on that truck!!!!!! Roll Tide. |
08-31-2013, 02:34 PM | #162 |
08-31-2013, 03:19 PM | #163 |
Here is 2 for 1....
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
08-31-2013, 04:37 PM | #164 |
08-31-2013, 07:26 PM | #165 |
They are 18 x 8 Centerline smoothies at all 4 corners,I saw what Delmo was doing with his and followed his lead. I had a sign maker friend cutout the white centers and apply them to the wheels. Same material that they use to wrap vehicles in for advertising. I was hoping to keep a bit of the old factory look. White wheels, chrome rings and centre caps. Photo on right shows what I started, 16" stock steel 6 lug wheels, painted white with stock GMC hub caps. withI am going to have the same sign maker make up some GMC decals to replace the centerline logos.Tires are 275-45 Continental Extreme Contacts. They were clearing the tires out at Tire Rack for $88.00 each, quite a good deal.
08-31-2013, 08:52 PM | #166 | |
08-31-2013, 09:24 PM | #167 | |
08-31-2013, 10:32 PM | #168 |
Hard to tell without bed on but it has bags and was set up with a slight rake
Posted via Mobile Device |
09-25-2013, 09:34 PM | #169 |
Gotta have a nice rake,big wheels in the rear,has to be a swb because a lwb is like a 4 door car.V8,lowered
09-25-2013, 10:00 PM | #170 |
10-09-2013, 04:08 AM | #171 |
I like how my 63 is set up. 2" block and drop spings in the rear, drop springs up front and spindles.
10-09-2013, 11:09 AM | #172 | |
This is perfect!
Supercharged Scottsman Scottish by birth, American by law, Texan by the grace of God. “To avoid criticism say nothing, do nothing, be nothing.” ― Aristotle |
10-09-2013, 11:13 AM | #173 |
Yep. Just wish we could get some specs on it.
10-09-2013, 11:27 AM | #174 |
Picture of mine with a load. Levels the truck out and looks good that way!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-10-2013, 08:53 AM | #175 |
Here is a picture before 2.5" front drop
after drop spindles and adjusting the rear air bags: |
