Old 05-28-2017, 10:33 PM   #1
bodyman9174
Swapping from v6 to v8
Hey all is it possible to use the ECM and engine wiring from a 94 c1500 in a 95 c1500? Will the air bag still work? And what about the ABS Are them separate from the engine ECM ? Little lost here I'm trying to put a 94 305 and trans into a 95 that had a 4.3. Or could I just use the V8's ECM? I have read that I will burn up the trans. But I have also read that I will just get check engine light on.Man I hate all this computer crap.. I need to stick to body and paint easy.
Any help would be great.
Cars i have done
bodyman9174 is offline   Reply With Quote
Old 05-31-2017, 08:10 AM   #2
Re: Swapping from v6 to v8
Wish I could answer your questions. Hopefully one of the better tech guys can give you an answer.
Palf70Step is online now   Reply With Quote
Old 05-31-2017, 09:32 PM   #3
bodyman9174
Thanks me to i think I'm just going to put the 94 PCM in there and hope for the best
Cars i have done
Old 06-07-2017, 11:27 AM   #4
rickpilgrim
I was told by my trans rebuild shop when I was contemplating the 98 5.7 swap that our 96 S10 with 4.3/4l60E/4wd 3.42 would need the complete ecm and wiring from the 98 5.7 plus a k1500 4l60e to make it work as the 4.3 has some pressure control on the trans that the v8 trans does not.
rickpilgrim is offline   Reply With Quote
Old 06-07-2017, 09:52 PM   #5
bodyman9174
i'm hoping with only 1 year different it will work.. I'm using the ECM motor and trans. All the wiring plugs in so hope to find out this weekend
Cars i have done
Old 06-07-2017, 11:32 PM   #6
91short
You want to use the ECM from the 4.3 on the 5.7? I think you'll need the V8 ECM but I'm not sure.
91short is offline   Reply With Quote
Old 06-08-2017, 12:33 AM   #7
bodyman9174
No I have the ECM motor and trans from the donor truck 94 305 V8. Put the motor in a 95 that had a V6. So going to use the ECM motor and trans From the 94.
Cars i have done
