12-02-2019, 05:39 PM | #1 |
'54 front tire/wheel situation
I just bought a '54 GMC step side short box sitting a '69 C10 frame. As you can see in the picture, the front wheels sit almost flush with the outside edge of the front fender. The wheels are 15" x 6" with a 2 3/4" setback from the outside edge of the rim to the mounting surface of the lug nuts. I would like to put taller tires on that would stick up into the wheel wheels. I see 2 possible solutions. Have wheels made with more offset to the inside (probably an additional 2", which I don't know if that's doable or not. That would mean a wheel with only about 3/4" offset to the outside. The other would be to get some shorter A arms that would pull the wheel in (see pic). It looks like (if they are available) I could move in about 2". Anyone have any suggestions on these ideas or some other option?
12-03-2019, 12:06 AM | #2 |
Re: '54 front tire/wheel situation
That just flat goes with the territory when you swap a 69 or later chassis under an AD truck. They are too wide to run anything except wheels with a lot of backspacing. That has been discussed on the net time and time again when guys think they are going to go cheap with one of those chassis.
12-03-2019, 02:56 AM | #3 |
1) Cut out that suspension and install an aftermarket Mustang II?
2) Widen your fenders? I saw a truck for sale on CL that had added a 4" strip of metal down the center of front and rear fenders. It actually looked great. 3) Sell that truck and buy another that's set up the way you want?
1951 Chevy Panel Truck |
12-03-2019, 10:27 AM | #4 | |
12-03-2019, 08:43 AM | #5 | |
12-03-2019, 02:26 PM | #6 |
more backspacing typically start hitting things like the tie rod ends or A arms when turning
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-03-2019, 03:14 PM | #7 |
I think I can mock up a wheel using wood and cardboard that I could bolt on and turn each way to see how close it gets to other items. It looks like I will need to go to 18" or possibly 20" wheels to clear the upper ball joint. Anyone else have any suggestions on how to figure out what will and what won't work? Fender clearance won't be an issue - there is a lot of room in there!
12-03-2019, 04:11 PM | #8 | |
https://www.ifabspeed.com/product-page/wheel-tool-2 If you're going really low you may have an issue with your tire rubbing the inner fender at the rear.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
12-03-2019, 04:11 PM | #9 |
I'll be looking for rims when my project is nearing completion. I saw the Detroit Steel Wheel site, it does look custom. I'm interested in a stock look. I found the site for US Wheel, seems to have a lot of offerings, and stock hubcaps.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
12-03-2019, 01:41 PM | #10 |
1 - If you have fab skills you could cut and narrow the stock A arms, I'm sure there is some info on this in the 67-72 section of this forum.
2 - You can buy narrow A arms from Porterbuilt, Choppin Block or other vendors, I think they're around $1000. 3 - Depending on the style of wheel you want I would think you could find some with a high offset if you don't mind the look.
12-03-2019, 02:16 PM | #11 | |
