06-08-2014, 02:10 PM | #1 |
Ignition switch issue
My 1966 C-10 has an ignition switch like the center one in the pic with the wings. If you turn it all the way left with the key in and then remove the key it is locked. If you turn it one click to the right from the locked position and remove the key you can start it with out the key.
Is this an optional 64-66 ignition switch or is it a replacement from some other Chevy. I thought the 1966 should have the flat top switch like on the left or right. My switch is acting up occasionally and I may replace it if I can't fix it. I like the one with wings but which is correct for a restoration. Does anyone know the applications for the different year trucks? PS I found these pics on the e-net...
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
06-08-2014, 03:46 PM | #2 |
Re: Ignition switch issue
I found this link on the board, good info. I guess I have the Impala switch mentioned in this link.
Would only the flat ignition key cylinder be stock? http://67-72chevytrucks.com/vboard/s...d.php?t=528310
06-08-2014, 05:46 PM | #3 |
my 64 chevelle had the one in the center that you could unlock ign. and remove key and start without it
06-09-2014, 05:17 AM | #4 |
My truck came with the flat one, and it also would turn without the key if you didn't take it all the way left.
Bought a replacement at napa, and it l;ooked the same as the center one. |
06-11-2014, 06:51 PM | #5 |
The one with the wings is correct for 1966--based on ALL I have seen. There should be even one more position to the left, in addition to the "lock" position you described. It would be the "acc" position, where radio and such other accessories will be switched to power without fear of burning the points/running battery down when regular ignition is turned "on".
Enjoy that truck...and show us pictures. Sam |
06-11-2014, 07:21 PM | #6 |
I just went out and checked my switch again, and your right...
My switch has 5 positions, starting all the way to the left (ccw): Acc, lock, unlock, on, start. I never knew that the Acc position was there, never used it. COOL! Well, if mine keeps acting up I will have to replace it. But I will replace it with the 5 position type with wings. Do all you 66' owners with known original ignition switches have the wings? Calling all original trucks??? report in.
06-11-2014, 07:24 PM | #7 |
Can't verify it's original, but my '66 has the flat (no wings) switch.
66 Custom Camper 327/ 4 spd. Bone Stock, down to the split rims |
06-11-2014, 07:34 PM | #8 |
Tell us how many positions your switch has, I suppose the flat ones could have 5 as well.????
06-11-2014, 07:52 PM | #9 |
Don't know, I'll have to check, but I think off, on and start? I'll have to see if it has acc to the left. Hasn't had a working radio since I bought it almost 20 years ago and don't have any other "accessories" to run
06-11-2014, 11:59 PM | #10 |
The wings were added on the '66 switches so you could leave the sw. in a position that would allow starting without use of a key. Great for farm use--quite often farmers would buy & use such trucks on the farm and never drive on a public road. No license tag, no key, no hi-speed driving, no paved roads. Only dusty, personal, dirt roads & pastures on their farm property. No-key safety issues solved by trucks being enclosed & protected by hog-wire & often cattle-proof barbed-wire fences!
After all, back then, who would ever steal a farm truck??? Sam |
06-12-2014, 11:13 AM | #11 |
06-12-2014, 12:11 PM | #12 |
Same here. Multiple '66's with the flat-top three position switch just like that.
06-12-2014, 12:39 PM | #13 |
2nd owner - 66 - no wings
3rd owner 64 - no wings ? owner 65 - no wings |
03-04-2018, 07:53 PM | #14 |
My 66 had no wings 4 positions; Acc, off, on, start. I replaced it when it would occasionally emit a lot of smoke. The replacement (Classic Ind,?) has 5 positions. I'm not sure what the extra position is for.
