Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-15-2017, 02:08 PM   #1
trukman1
Winch motor rebuild question
The rotor has portions on it where the "coating" is chipped away. I purchased spray on coating at Grainger's but want to know when I spray it should I coat the commutator part also or leave it bare? Thanks
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 04-15-2017, 08:00 PM   #2
starterman99
starterman99's Avatar
Re: Winch motor rebuild question
You want to leave the commutator bare.you should clean it to get a good clean surface for the brushes to ride on.
1950 5 window
starterman99 is offline   Reply With Quote
Old 04-17-2017, 01:46 PM   #3
trukman1
Thanks! I had to ask because I didn't think it could make for a good contact surface if it were coated but I saw pictures of the rotors being dipped into the coatings and wasn't sure. That's the great thing about having so many resources available on this site. Thanks again!
Old 04-18-2017, 03:09 PM   #4
trukman1
I realize I have another question. Do I need to tape off the steel "middle" section of the rotor (the steel part that passes by the field windings?) Or do I caot the center and clean it off later so the wires running through it get coated?
Old 04-19-2017, 11:16 AM   #5
starterman99
you can paint it. The winding should be deep enough in the slot and insulated so that light sanding wont remove the insulation and cause shorting. just use caution to not over clean it to where you could cause a problem.
1950 5 window
Old 04-19-2017, 11:38 AM   #6
trukman1
starterman99, Thanks for all your help. I greatly appreciate it. trukman1
