Old 04-21-2013, 01:07 AM   #1
Aarons72
Aarons72's Avatar
Rectangle holes on rear pillars...do i need them?
I am cleaning up and painting etc...Wondering what these holes are for and if I need them for anything? What are you guys doing with them? Would it be fine to weld them shut?
Also...The seam on the roof toward the back of burbs...any problems that arise from welding that up?
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 04-21-2013, 01:17 AM   #2
pritch
pritch's Avatar
Re: Rectangle holes on rear pillars...do i need them?
The rectangle holes are for the other option on the doors. If you have the clam shell, your hinges are in the top and bottom set of hinge points, and with barns, the hinges are on the right and left pillars.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 04-21-2013, 11:54 AM   #3
Aarons72
Aarons72's Avatar
Ahh...Gotcha. So If I never want barn doors then I can close them up.
Aaron Anderson
*1962 Nova
Old 04-21-2013, 12:27 PM   #4
pritch
pritch's Avatar
Yes.
'68 Panel
'68 C-10
Ol' Green
Old 04-24-2013, 12:01 PM   #5
jorgensensc
jorgensensc's Avatar
Let me know when you get rid if the little plugs! I need a few for mine.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
