10-24-2017, 10:33 AM | #1 |
Positive camber w/disc conversion
I've got a 69 C30 Longhorn frame that I'm turning into a Ratrod. The cab and bed were completely rusted. The truck had "normal" camber with it's original drum brakes with about 3/4" of shims. I got spindles off of a 74 C20. Now I appear to have a positive camber issue on the right side only. The left looks just fine with 3/4" of shims. I took out all of the shims and it still looks positive. I got drop spindles and it still looks positive. Will the offset upper control arm shafts work to help correct this issue? Thanks.
10-24-2017, 11:25 AM | #2 |
Re: Positive camber w/disc conversion
I am not sure how those new parts would change the camber if they are installed and seated correctly. I would double check to see that the springs are in the pockets correct and everything is tight. Have you driven or moved the truck yet after the parts swap?
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-25-2017, 08:12 AM | #3 |
Thanks for the reply. The springs and ball joints all "look" right. After assembly, I drove the truck on a smooth road. I'm going to finish wiring my lights this weekend and then look more closely at that right side. I'll take some close up pictures of the suspension. Maybe someone will see something that's evading me.
