Old 07-06-2013, 10:31 PM   #1
LMREESE
4x4 conversion pics
I would like to see some pics of 2 wheel drive to 4 wheel drive. Looking for pics of actual conversions not just body swaps. I specifically want shots of the transfer case and in the cab where the shifters come through the floor. Thanks.
67 C10 swb bored out 350 granny 4 speed
I come from a long line of moonshiners
LMREESE is offline   Reply With Quote
Old 07-08-2013, 07:22 AM   #2
andrewmp6
Re: 4x4 conversion pics
Like http://67-72chevytrucks.com/vboard/s...d.php?t=310493
Old 07-19-2013, 09:01 PM   #3
dennislbrooks
The Man, the Myth, the Legend
dennislbrooks's Avatar
I used a NP 208 behind a 350 turbo. The shifter is from a Chevy 1990 ton NP 241. It was on driver side of hump. I turned it around and put it on the passenger side. I fabricate what ever I need. Lever position is in 2wd. Pulling it back takes to 4H, neutral and 4L. The Ford shifter has the correct pattern on it.
dennislbrooks is offline   Reply With Quote
Old 07-19-2013, 09:04 PM   #4
dennislbrooks
another picof use of switch on np 208. Green light comes on when in an 4wd.
Old 12-15-2013, 12:09 AM   #5
1970/327/c10
1970/327/c10's Avatar
Here's my conversion, everything is original to the frame. If you doing an all original swap like I did, there not much stuff to worry about. There's stuff that you have to change like, shift linkage (possibly, I had to on my). Have to change the transmission tunnel unless you already have a manual. Cab mounts and dont buy the cheap ones from oreillys go to lmc and get there kit. I also had to change my radiator hose on the bottom. You will have to watch you distributor to cab clearence. axle with disc brake conversion is one of the best things you can do, it was the cheapest thing and easiest to install.
Drivin People Insane With my Classic Chevy!
1970/327/c10 is offline   Reply With Quote
Old 12-15-2013, 07:03 AM   #6
dennislbrooks
I like it MO, I picked up a SS 454 14 bolt G80 3.73 for mine and converted it to 6 lug and added rear disc brakes. 5 to 6 was less complicated when I also used a 1.5 inch hub centric spacer.
Old 12-15-2013, 05:41 PM   #7
woodwright
Enjoying left field
woodwright's Avatar
The one in my sig is a 2wd to 4wd swap. Little different though.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 12-15-2013, 11:38 PM   #8
66skylarkpost
66skylarkpost's Avatar
my 87 shortbed build http://www.67-72chevytrucks.com/vboa...d.php?t=576936
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 12-31-2013, 03:58 PM   #9
splehigh
splehigh's Avatar
Nice! How do you like the dual shocks?
splehigh is offline   Reply With Quote
Old 12-31-2013, 07:21 PM   #10
OrrieG
OrrieG's Avatar
59 frame and springs with 74 K10 drivetrain. 350/350TH/NP203 3.73 gears. 16" steel wheels. Lots of details in my build thread.
Old 01-02-2014, 07:20 AM   #11
splehigh
splehigh's Avatar
Sorry about that. I had some login trouble and then commented on the wrong thread.
Old 01-02-2014, 11:00 AM   #12
1968vetL-71
Junior Member
1968vetL-71's Avatar
Not sure what body style or years your wanting. Here's my 91' R30 converted to V30. Not finished yet but should be in couple weeks.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 01-02-2014, 11:02 AM   #13
1968vetL-71
Junior Member
Now
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
