Old 08-15-2019, 11:28 AM   #1
85chevytrucker
72 gmc duramax build
Hi thought I'd start a build thread on my current project. It's a 72 gmc that I've had kicking around in my back yard for a couple years now. I also had a bunch of duramax parts leftover from previous builds and figured I might as well build something with it all. Frame was an 05 3/4 ton reg cab with 6.0. Stripped it down and moved axle ahead about 6 inches. Also had to put a shortbed fuel tank to clear axle and added a fass fuel system I had
85chevytrucker is offline   Reply With Quote
Old 08-15-2019, 11:35 AM   #2
85chevytrucker
Re: 72 gmc duramax build
Cab floor was rusty so I ordered one piece floor cab corners rockers and kick panels. Last weekend I cut the floor out. A few hours later cab floor was tacked in place and cab was set on frame.
Old 08-15-2019, 11:42 AM   #3
85chevytrucker
Sat the engine and trans in and then lowered cab onto frame to see how it fit. The floor fits the new chassis nicely. The bed floor will have to be raised about 4.5 inches to match cab. Engine is an lb7 with 68mm turbo profab manifolds and uppipes. Getting some bigger nozzles for it also.
Old 08-16-2019, 10:05 AM   #4
Snake72
Snake72's Avatar
Very nice work so far! The one piece floor replacements are great. I sprayed my new floor top and bottom with raptor liner to protect the new metal. How did the cab mounts line up on the duramax frame? Great choice on the LB7 too, I love my deleted LML daily driver.
Snake72 is offline   Reply With Quote
Old 08-16-2019, 10:46 AM   #5
85chevytrucker
Thanks. The front cab mount lines up with an existing hole in the frame. I just had to drill it bigger and pass a long bolt straight through. The rear mount interfere with fuel tank so I had to make new mounts I'll post pics when I get a chance. I wanted cab to sit lower but the rear is sitting on the fuel tank so without relocating fuel tank it's as low as possible.
Old 08-18-2019, 09:41 AM   #6
cornerstone
cornerstone's Avatar
You my friend are no slouch. Quite the undertaking! I'm in!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 3+ year frame off.
cornerstone is offline   Reply With Quote
Old 08-18-2019, 01:04 PM   #7
85chevytrucker
Got the rockers cab corners and kick panels welded in today. Started on the bodywork.
Old 08-19-2019, 07:05 PM   #8
85chevytrucker
Cut drilled and modified the hydroboost braket tonight and bolted it to the firewall. Also welded up the steering shaft.
Old 08-20-2019, 06:18 PM   #9
85chevytrucker
Built a new filler neck this evening. The only logical place to put the filler was back in the original location but seeing as tho I wanted to keep the new style tank I had to pass a pipe through the cab. I welded the newer filler neck where the old cap was and an exhaust elbow to back of cab. Hooked up the hoses and done.
Old 08-22-2019, 06:09 PM   #10
85chevytrucker
Got the radiator support mounted and fit the radiator and intercooler. It fit tighter than I was expecting. I'll have to mount an electric fan in front of the the radiator stack.
Old 08-22-2019, 08:01 PM   #11
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Looking good.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is online now   Reply With Quote
Old 08-23-2019, 02:25 PM   #12
Daubs
Daubs's Avatar
This. Is. Awesomeness!
'72 Chevy K-20 Crate 350, SM465, 4.10's
'04 Chevy 2500HD CC 4x4 8.1L/496, Allison, 3.73's
Daubs is offline   Reply With Quote
Old 08-24-2019, 09:22 PM   #13
72 tigger
72 tigger's Avatar
Nice fabrication and welding skills
72 tigger is offline   Reply With Quote
Old 08-25-2019, 04:48 PM   #14
85chevytrucker
Thanks. Not as much progress as planned this weekend but I did run fuel lines and trans lines. Going to hook up radiator and intercooler piping this week and hopefully tackle engine wiring. Should be running by the weekend
Old 09-16-2019, 07:08 PM   #15
85chevytrucker
Got a bit of work done to truck. Intercooler piping is done as well as coolant hoses. Mounted throttle pedal and built shifter linkage. Also wired up engine and fired it up. Just need to build a driveshaft and I'll be able to move it around
Old 09-17-2019, 01:23 PM   #16
67C10GS
67C10GS's Avatar
its nice to see someone tackle a dmax build every once in a while. cant wait to see it rip around.
1967 GMC C15 sb ls swap turning into a pontiac formula 10 "what if" truck
67C10GS is offline   Reply With Quote
Old 09-17-2019, 06:45 PM   #17
85chevytrucker
Yea it's a nice change of pace. Done so many ls swap they were kinda starting to get boring. Took a short vid of first start last night. Wiring is mess going to mount battery pcm and tcm and then clean up harness. Link to vid https://m.youtube.com/watch?v=inFJgk2cx4Q
72 gmc, duramax conversion, duramax swap, floor replacement
Copyright ©2000 - 2019, vBulletin Solutions Inc.
