05-26-2018, 10:06 PM | #1 |
1966 c10 mirror location
I got repos doors. I did not look at my old doors before i sold them. I need to know the measurement to the center of the bolts?
05-26-2018, 10:56 PM | #2 | |
But Found Her 25yrs Later!
Re: 1966 c10 mirror location
I'll see if I can find it.
05-26-2018, 11:02 PM | #3 |
I guess it was for a 61-63:
http://67-72chevytrucks.com/vboard/s...ghlight=Mirror I'll keep looking.
05-27-2018, 06:53 AM | #4 |
Moderator
Hi rvrfoot, the only thread I can find on that you already posted on last year.
http://67-72chevytrucks.com/vboard/s...d.php?t=685694 It's the actual measurements of the holes is what you need. If you have time I can make a template and send it to you of the drivers door, then just transfer to the passenger when ready. I don't have my door mirror on yet.
05-27-2018, 09:09 AM | #5 |
Moderator
Sent you a PM.
05-27-2018, 10:10 AM | #6 |
Sent back thanks.
05-27-2018, 06:07 PM | #7 |
Can you send me that as well please?
PO welded all the holes up for my driver side door so I can't copy anything over either. Thanks, Dan |
05-27-2018, 07:02 PM | #8 |
There should be a triangular shaped reinforcement with 3 captive nuts spot welded to the inside of your drivers side door where the mirror mounts. Try to use that to recover your holes for the correct location.
05-27-2018, 08:17 PM | #9 |
Moderator
You'll have to get rvrfoot to send it after I send it to him.
05-27-2018, 09:53 PM | #10 |
05-27-2018, 10:15 PM | #11 |
I to need the template as I recently had to purchase new doors and need to mark the mirror holes.
Pat |
05-27-2018, 10:26 PM | #12 |
That would be great.
05-27-2018, 10:38 PM | #13 |
05-28-2018, 08:45 AM | #14 |
05-28-2018, 12:48 PM | #15 |
I'm sure that repro doors don't, but DLW mentioned that a PO had filled in the holes in his doors.
05-28-2018, 05:26 PM | #16 |
You might be right about the stock nuts still being there on my truck, although welded over. I will keep that in mind to make a template from inside the door if possible. If this template Rocknrod made is accurate though, it might be nice to have and easy to make more of them. Surprised there is no template out there yet for 64-66. I think we need to find a way to get that template, or another one like it, in PDF that prints in real size so you don't have to physically mail it around.
06-01-2018, 08:57 PM | #17 |
