Old 06-25-2018, 01:27 PM   #1
mister.freeze
mister.freeze's Avatar
Blazer Rockers
Do Blazers have an inner rocker panel? Or does the rocker box do that job? My outer rockers are almost gone and I done see any remnants of and inner rocker. Just trying to get an idea of what I'm getting myself into. Oddly, my rocker boxes are in GREAT shape.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 06-25-2018, 03:48 PM   #2
SeventyOne
Re: Blazer Rockers
Yes on the inside of the curved outer rocker is a flat piece that makes a 90* angle with the floor. Search for rocker replacement images and you'll see plenty of images of the guts there.
SeventyOne is offline   Reply With Quote
Old 06-25-2018, 04:55 PM   #3
mister.freeze
Re: Blazer Rockers
Ok, thanks. I can see straight into the rocker boxes, so they are either missing or rotted out worse than the outer rockers. Anybody sell a THICKE rocker set than OEM or reproduction?
Old 06-25-2018, 05:58 PM   #4
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: Blazer Rockers
Let me know if you find any... mine are the thin stuff... i think they get dented when i look at them too hard...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2015 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 06-26-2018, 05:50 PM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Blazer Rockers
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, 3.73 positraction, 16.5"x8.25" wheel option, tach, manual throttle...original family owned. Under restoration...
1972 Cheyenne Super 20 2WD, DK Blue/White, 82K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
Old 06-28-2018, 10:28 AM   #6
mister.freeze
Re: Blazer Rockers
wow. That's a big deal. Are the clecos just to hold it or are you going to rivet it in?
Old 06-28-2018, 10:32 AM   #7
raggedjim
raggedjim's Avatar
Re: Blazer Rockers
I welded mine, that's how the factory did it.
Good luck, Rg
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-28-2018, 08:28 PM   #8
lks dcvn
lks dcvn's Avatar
Re: Blazer Rockers
Here is a break away (rusted away actually) view of the blazer side from an old project of mine.
lks dcvn is offline   Reply With Quote
Old 06-29-2018, 08:41 AM   #9
mister.freeze
Re: Blazer Rockers
thanks for that. looks like I've got some work ahead (x2). I had thought about making an inner rocker out of something thicker to tie the rocker box and floor together, but it looks a bit more intricate than that.
Old 06-30-2018, 08:54 AM   #10
1970cstblazer
Re: Blazer Rockers
The repro panel is a good one. For a Blazer application the rear of the panel will have to be slightly shortened. The panel was designed for a regular pickup cab, but works fine on a Blazer.
Old 06-30-2018, 11:18 AM   #11
mister.freeze
Re: Blazer Rockers
If I remive the fender and door, will I see the end if the firewall like in your first picture?
Old 06-30-2018, 01:55 PM   #12
1970cstblazer
Thumbs up Re: Blazer Rockers
The fender, inner fender skirt, and door will need to be removed to see the firewall as seen in the supplied photo.
Old 07-03-2018, 09:09 PM   #13
lks dcvn
lks dcvn's Avatar
Re: Blazer Rockers
When I did the rust repair on that part of my blazer rebuild - I was given a free part to test the fitment with a new aftermarket piece - have a look here at my review. It wasn't that tough.
http://67-72chevytrucks.com/vboard/s...d.php?t=375946
Old 07-03-2018, 09:34 PM   #14
mister.freeze
Re: Blazer Rockers
I'm pretty sure I won't need that part... fingers crossed!
Old 07-05-2018, 01:31 PM   #15
SeventyOne
Re: Blazer Rockers
Hows your B pillar? Also any rot in the floor pan?
If you have floor pan rot your subframe might also be gone.
Old 07-05-2018, 06:24 PM   #16
mister.freeze
Re: Blazer Rockers
Floor is good at the b pillar on both sides. Just rockers and usual adjoing floor
Copyright ©2000 - 2018, vBulletin Solutions Inc.
