08-18-2019, 04:26 PM | #1 |
6.0 swap with 4L60E not shifting
I'm about finished with my 48 COE, but having a transmission problem, first of all just in case it could have something to do with it. When it's cold it will start right up but will not idle on it's on for about 30 seconds then it's fine. I can take off in first and shift manually up to 3rd ( won't go into 4th). If I start in drive it is in safe mode and starting in 3rd. I'm getting 3 pending faults of P0740, P0753 and P1860. I fell like it is in the wiring, not getting a signal from something telling it to work, I have power to pin 33 from normally closed brake switch. Ive got power on pink wire to tranny. I'm not sure what other wires to check, also it's a after market wiring harness.
08-19-2019, 06:00 PM | #2 |
Re: 6.0 swap with 4L60E not shifting
Surely somebody has some idea for me to try. I'm worried if I keep drive it the way it is I may ruin the transmission.
08-19-2019, 10:33 PM | #3 |
Most 6.0's had 4l80's behind them, not 60's, so if your PCM thinks it has an 80 then it needs to be reflashed. Other than that, if you think it is a wiring issue, what brand of harness do you have?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-19-2019, 11:09 PM | #4 |
60-66 Nut
I agree that a 6.0 typically has a 4L80E behind them.
08-20-2019, 09:07 AM | #5 |
Pcm was set up for 4L60E, can't remember what company did harness, had it done several years ago. It wasn't street and performance but it was something similar, they are out of business now
08-21-2019, 07:52 AM | #6 |
Has the transmission ever worked correctly in this truck or is this the first time you have driven the truck with this 4L60E transmission
What year is the 4L60E trans ? Do you have the pinouts of the connector going into the transmission. You state you have voltage on the pink wire, do you have voltage in the trans harness as well ? Check the connector going into the transmission and or the harness in the trans to ensure you have voltage inside the trans. the issue you are describing indicates there is no voltage on ignition 1 pin going into trans, but need for you to answer the above questions in order to assist you at this point. |
08-21-2019, 08:08 AM | #7 |
Transmission worked in donor not this one, 1997 van tranny with 5.3, I have a pin out, pin e is the hot, all the solenoids have power at the solenoid, I benched tested all, they all clicked and seemed to be working, this is why I feel it's not getting the right signal from something telling it to work
08-21-2019, 10:34 AM | #8 |
What’s different from the donor truck to your project truck ? If it worked in the donor truck,did you use donor pcm and wiring ?
When you refer to pin 33 and brake switch what connector are you speaking about. Is that the TCC solenoid wiring and how is that setup thru brake switch Posted via Mobile Device |
08-21-2019, 11:09 AM | #9 |
Aftermarket wiring harness is only difference that I know of, pinn 33 is hot wire from normally closed brake switch, breaks the connection to the TCC when pedal is pressed. What else affects it shifting? VSS, TPS.
08-21-2019, 06:06 PM | #10 |
Since every thing inside the trans checks out per your bench testing, have you checked the wiring to VSS, have you replaced the VSS ? have you tested the TPS as well. Have you disconnected the brake switch and tried it.
08-22-2019, 03:18 AM | #11 |
Post Whore
first of all absolutely killer rig, but have you updated your tire size and gear ratio in HP Tuners, those settings impact the shift points
HP Tuners - Part III - Change Tire Size and Gear Ratio |
08-22-2019, 03:33 AM | #12 |
Post Whore
That things a beast...I'm guessing with only 6 posts (so far) ,,you dont have a build thread..
Would like to see more pics of it..
08-22-2019, 05:16 AM | #13 |
Had a similar situation as yours, when first getting my LS swap on the road. Did the same tests as you, too. Turned out to be a faulty PCM
08-22-2019, 07:23 AM | #14 |
Don't won't to hear that, but that's what I've been feeling. I wanted to try all possible things before that, as far as I know there's not anyone local that reflashes them. Thank You
08-22-2019, 11:00 AM | #15 |
Again, I was in your same situation, with no local tuner (that I knew of at the time), low bucks and a questionable vendor for harness and PCM reflash. Ended up seeking advice from www.PCMperformance.com out of New York. Sent them an email ('cause I'm an old fart) about the problem and could they reflash the current PCM. Ended up buying a new PCM, that was programmed to my trucks' spec's. They have you fill out a worksheet pertaining to all the vehicle spec's. Soon as I got the new PCM, it was instant wonderfulness! Now, three years later, my truck still runs excellent, even without seeing a dyno, as everyone wants you to do. Give them a shout, and see what they recommend. Good luck. And yeah, cool rig!
08-22-2019, 12:00 PM | #16 |
Can I ask what they charged you, I'm an old fart myself trying to live off SS
08-22-2019, 12:35 PM | #17 |
Ya know, I think the only thing that's gold in our "Golden Years" is the pee we put in the toilet!! I'm 72 and also on SS. But I'm still "young enough" to still play with my truck. I think the cost was around $495, but it was worth every penny when I saw how good the truck ran after going round and round on the "transmission" problem. Another thing I found quite helpful was a subscription (on-line) to AllData DIY. You get the vehicle your powertrain comes from (mine was a '05 Tahoe) and you have unlimited use of schematics, troubleshooting info, TSB's that pertain to the vehicle, DTC info, etc. The sub is good for a year, but I printed all of the schematics, pin-outs, and connecter info, which I keep on a clip board in the garage in case I need it later on.
BTW, this is my truck |
08-22-2019, 12:53 PM | #18 |
Nice, I like those square body's, I've got a 83 K10
08-22-2019, 01:12 PM | #19 |
Sorry, Gregski and Mongocanfly I totally miss your post, yes they had all my info as far as tire size and gear ratio, I'm getting a speed reading from obd2 port and it's right on with my GPS and I don't have a build thread, didn't have time as I was building it now that I'm retired I can do one
08-24-2019, 08:41 PM | #20 | |
I am sure HP tuner will fix every thing from the laptop, maybe plug in the joy stick and manual shift that 4L60E. Last edited by YoungPup1977; 08-28-2019 at 09:13 AM. |
09-14-2019, 04:25 PM | #21 |
Just installed new ECU from PCM performance, no change still won't shift
09-14-2019, 04:51 PM | #22 |
1965 Chevy C10, 2005 4.8L/4l60
Sounds like maybe a valve body, might take it to a trans shop for diag
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-16-2019, 08:51 AM | #23 |
Thanks, if it is the valve body would it shift manually?
09-16-2019, 12:55 PM | #24 |
Same trouble codes?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-16-2019, 01:39 PM | #25 |
Yes, same codes, I've ordered a new internal wiring harness for the tranny, to eliminate that, should be here in a couple of days
