09-14-2019, 04:08 PM | #1 |
Mini starter engage and release
Mini Starter and flywheel seem to be correct, and good fit. SBC 350...May add a shim. Not ready for start up but wanted to test to be sure starter spins when I turn the key, got about a 6th of a turn when I tap the key. Starter did not disengage, does it retract by itself or does the motor running throw it back?....Thanks in advance.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
09-14-2019, 07:35 PM | #2 |
Re: Mini starter engage and release
When the engine fires it will kick it out. Most the time if you just turn the motor back the other way just a touch the spring in the bendix will release it. A little friction is all that is holding it out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-15-2019, 12:44 PM | #3 |
Thanks for the response Jimmy, 1 shim took the friction off and seems to be fine now. Thanks again.....Ed.
