Old 05-14-2019, 10:02 AM   #1
72=c10
air ride question
i have air ride from bcfab on my 70 c10. i need to run 10lbs less air in the right rear than the left to make the truck set level. this is with the truck empty. anyone have any ideas what would cause this?
72 C10 6.0L 4L80E
72=c10 is offline   Reply With Quote
Old 05-14-2019, 12:53 PM   #2
69gmcc10
69gmcc10's Avatar
Re: air ride question
Do you have an aftermarket panhard Rod? If you have a lowered suspension and a factory panhard rod it will pull on the rear suspension making the rear axle not centered under the truck and can also lead to the bed/frame not sitting level.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 05-14-2019, 08:35 PM   #3
72=c10
I have the long one from cpp
72 C10 6.0L 4L80E
Old 05-15-2019, 03:33 PM   #4
SCOTI
SCOTI's Avatar
What air-ride set-up from BC Fab? What are the particulars?
What type of air management system?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 05-15-2019, 03:39 PM   #5
72=c10
Airlift 2600 bags
Avs electric valves
Avs 7 switch control box
480c compressors
72 C10 6.0L 4L80E
Old 05-15-2019, 05:23 PM   #6
SCOTI
SCOTI's Avatar
Was the air suspension just installed? Any other service work or suspension mods done prior to the 'air ride' install?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-15-2019, 08:37 PM   #7
72=c10
Shocks relocated
No other work
It has been like that since I installed air ride
72 C10 6.0L 4L80E
Old 05-15-2019, 09:35 PM   #8
SCOTI
SCOTI's Avatar
Shocks relocated
No other work
I would check for suspension bind first. Make sure all pivot point hardware is torqued to spec w/full weight on the chassis. Get it up in the air on jackstands (under the front a-arms as far out as possible & same on the rear axle). Loosen the pivot hardware & re-tighten.
Re-check & see if the issue persists. FWIW, my dually has diff pressures @ all 4 corners & even that varies depending on temps.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2019, 01:53 PM   #9
Backpayne
Could just be your gauge.
Backpayne is offline   Reply With Quote
Old 05-18-2019, 07:27 PM   #10
koz
Measure RH with you sitting in the truck
koz is offline   Reply With Quote
Old 06-07-2019, 01:10 PM   #11
JGRNTC10
Is the issue just that the pressures are different. The psi difference wont matter if you achieve the desired outcome..
JGRNTC10 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
