01-16-2019, 05:02 PM | #1 |
Which flywheel,clutch setup
I’m looking for the correct size flywheel and clutch for my 292 with 3 speed. I need help!!!
01-17-2019, 02:31 PM | #2 |
Re: Which flywheel,clutch setup
should be a 168 tooth flywheel. I think 292 flywheels have bigger bolt holes than a 283/235. somebody should chime in TJ?
1961 chevy K10 my build is------------61K10 build |
01-17-2019, 05:22 PM | #3 |
01-17-2019, 08:22 PM | #4 |
'67 - '71 292s had 11'' flywheels, '72s had 12''. 292 L6 was same as SBC.
'67 and later 292s have six 1/2''-20 bolts and 3 dowel pins [.4520-27''] securing flywheel to cam end. L6 292s from MY '63 - '66 used six 7/16''-20 bolts and one dowel pin, like the 250s and 230s. Santucci recommends upgrading to the 1967 standard.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-17-2019 at 08:30 PM. |
01-17-2019, 09:07 PM | #5 | |
01-17-2019, 09:27 PM | #6 | |
When I R & R ed my 292 in '05, I got dowel pins from the Chevy dealer -- they didn't fit. I got Leo Santucci's specified .452~'' pins, they didn't fit right either. My machinist came up with 3 pins that did fit, but I didn't mic them for posterity. My advice is to play that size by ear. The 292 is a torque monster, so don't skip the dowel pins. Santucci gives an alternative in his book: "Chevy Inline Six Cylinder Power Manual," you could have the machinist tap the dowel pin holes to 1/2''-20 and use 3 more bolts there, but they have to have 12-point heads for clearance. Really a competition grade option.
01-18-2019, 03:05 AM | #7 | |
01-18-2019, 06:41 AM | #8 |
They should be all over it.
01-18-2019, 07:37 AM | #9 |
im just glad its in pieces still... plus they are less then 10mi away.
06-24-2019, 11:41 PM | #10 |
Any update to your situation? I'm just now finding out that the new crankshaft in my 292 is tapped for 1/2" bolts, but the flywheel that I had the machinist resurface has 7/16" holes.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
06-25-2019, 12:43 AM | #11 | |
Just have the machinist rebore the holes to 1/2''. L6 292 had 6 bolts and 3 dowel pins. L6 250/230s had 6 bolts and one dowel pin.
06-25-2019, 01:00 AM | #12 |
Ok. So it looks like I have the flywheel from a 250. Which is entirely possible because we did have a 250 in the truck when we got it. I think I'd be better off getting the correct flywheel with the the three dowel holes for the 292. Its faster to get a new one than send one out and wait for it to get done. Thanks for your reply '68OrangeSunshine.
06-25-2019, 05:36 AM | #13 | |
Santucci's book lists the crank end bolt holes as six in 1/2-20 UNF, and the three dowel pin holes to be reamed to .4520 - .4527''. L25 MY '67 and later did have the half inch bolts. [L25 is the 292 L6's SPID code.] I'd be more worried that the new replacement flywheel wasn't made in the USA to proper industrial tolerances, than I would worry about real Detroit steel of the right vintage.
