09-06-2010, 03:57 PM | #51 |
PROJECT 7DEUCE
Re: Future gasser '57 chevy
Cant wait to see this one done..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-06-2010, 05:49 PM | #52 |
mmmmmm.... makes me want to build another!
Good work on your patch panels, thats quality right there lol
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
09-18-2010, 07:04 PM | #53 |
09-18-2010, 07:10 PM | #54 |
I have some detail shots of a tri five truck that was at this past year's Lonestar Roundup here in Austin. It had the cool gasser look. I am thing of going that route with my 55 big window. I will see if I can find them.
10-07-2010, 01:05 PM | #55 |
Thanks to all of you that are following my gasser build - it gives me encouragement to continue forward when I struggle to make excuses why things are not getting done.
I should have the body work on the cab done and in prime pretty soon and will post pictures! |
10-07-2010, 07:02 PM | #56 |
I was super close to doing a gasser, but went the clip route. I am glad to see someone else moving forward with it!
10-17-2010, 12:48 AM | #57 |
We are done with the body work on the cab with the help of my good friend Daniel. Here are a few pictures of work in progress.
I just celebrated my 58th birthday! |
10-17-2010, 12:57 AM | #58 |
Here are a few more pictures with the first coat of primer. Hope to have the cab block sanded later in the week.
509nat |
10-17-2010, 04:46 AM | #59 |
A320 Pilot/USAF Retired
Wow, it's really coming together nicely!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-17-2010, 09:30 PM | #60 |
TOo bad you are so far off. I could drop off my half completed for 15 years 55 big window to let you do the same to it.
10-17-2010, 11:04 PM | #61 |
Nice build you got going.........very inspirational.
I'm wondering if I could get that "Gasser" look by just lowering the back and leave the front stock..... kind of a lowrider gasser...(maybe not). Curious on what you are going to use for motor mount and what transmission your going with (sorry if perhaps maybe I missed this earlier in post). |
10-18-2010, 05:21 AM | #62 |
Sorry so long for the photos. It looks like their lift is with shackles. I didn't get a chance to ask him how it drove, though.
10-25-2010, 10:37 PM | #63 |
hsdropout - Sorry for the delay!
Here is a list of some of the parts from www.SpeedwayMotors.com used on my gasser project: Hope info is useful 910-31916 deluxe disc brake kit 910-32132 power steering kit 910-32130 kingpin set 720-4771 motor mounts kit 79-161 polyurethane rear motor mounts -www.ClassicParts.com Using a Chevy 409 big block, stock bellhousing and clutch setup hooked up to Borg Warner super T-10 4 speed tranny. Last edited by 509nat; 10-25-2010 at 10:41 PM. |
10-25-2010, 10:44 PM | #64 |
10-30-2010, 08:25 PM | #65 |
Here are the latest pictures of my project Future Gasser '57 truck. Installed the 409 in the frame to check for clearance issues. Installed the new 409 ceramic coated headers part number #65722 from Edelbrock and they fit great, polyurethane rear motor mounts and side motor mounts and bolted to frame. Set clearance on the front pulley 1/2 inch on top of front cross member and rear of valve covers are about 1/2 inch from firewall. Clearances all around the motor look good.
509nat Last edited by 509nat; 10-30-2010 at 08:34 PM. Reason: Spelling |
10-30-2010, 08:31 PM | #66 |
A few more pictures!
509nat |
10-30-2010, 08:52 PM | #67 |
Nice looking truck you got going there. Happy belated B-day and keep the pics coming. also any plans for a color yet?
http://67-72chevytrucks.com/vboard/showthread.php3?t=145432 |
10-30-2010, 08:54 PM | #68 |
PROJECT 7DEUCE
That motor is over the top!!!
10-30-2010, 11:11 PM | #69 |
Looking great, keep up the good work. I'm really enjoying seeing this come together and can't wait to see the finished product!
10-31-2010, 12:00 AM | #70 |
Looks great, love the engine.
Kim |
10-31-2010, 11:36 AM | #71 |
Yellow truck club
She's so fine .......
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
10-31-2010, 12:45 PM | #72 |
10-31-2010, 03:19 PM | #73 |
I was (am) considering a 409 and was wondering - where did you get the motor from? Those things are expensive, even in rough form......I have seen rebuildable 409s for around $4k.....
10-31-2010, 05:54 PM | #74 | |
Needless to say it has been spendy adventure, but I am enjoying the results. 509nat |
11-27-2010, 12:29 AM | #75 |
Amazing truck bro. That 409 was a good choice for your center piece.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
