08-23-2019, 01:04 PM | #1 |
Stranded in middle nowhere, 1987/350 manual ECM fuze blown
I had another fuze in the truck, plugged it in and it blew...
Any ideas to get me back on the road? Thanks! |
08-23-2019, 01:08 PM | #2 |
Old member
Re: Stranded in middle nowhere, 1987/350 manual ECM fuze blown
Sounds as if you have a straight to ground issue.
Which fuse is it?
08-23-2019, 01:21 PM | #3 |
ECM 1 fuze
08-23-2019, 01:41 PM | #4 |
Wonder if I pull the 30 amp accessory fuze I might get lucky and it will start? Only have one fuze left
08-23-2019, 02:18 PM | #5 |
Found it after much searching, a frayed wire at the injector area.
08-23-2019, 03:54 PM | #6 |
08-23-2019, 09:45 PM | #7 | |
BMW & ASE Master Certified
if it was 30, I'd say why not... never put a larger amp fuse in place of one that's instantly blowing, your asking for a much bigger problem than you had such as a fire. even if its just to get you home... clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
08-25-2019, 11:09 PM | #8 |
Old member
Glad you found it. Sorry haven't been on the computer in a couple of days. Had no internet.
08-26-2019, 05:14 PM | #9 |
ECM 1 is a 10 amp, I was only going to pull the 30amp to see it affected the short, not use it in place of a 10 amp.
Thread Tools | |
Display Modes | |
