Old 03-18-2019, 10:08 AM   #26
Nodnarb76
Nodnarb76's Avatar
Re: Am I right on my Troubleshooting codes PO171 & PO174?
Well this past weekend, I replaced my regulator (used the C5 Corvette regulator/filter), inline filter and the gauge on my fuel rail. I still have fuel pressure in the upper 40's. I am now suspecting the fuel pump, the hose between the sender/pump. Or I'm not getting a full 12v at the pump.
I Should be getting 58psi at my gauge on the fuel rail with the engine running if I'm using the C5 filter/regulator correct?
I would like to post up some pics of the freeze frame data from when the check engine light comes on to see if anyone has some ideas.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
