01-09-2012, 03:04 AM | #1 |
Q about serpentine belt
Hi,
I have GMC 1984, it has 350 engine. I want to upgrade the serpentine belt to one serpentine belt as the new engines. How Can I make it? Should I change the waterpump? Is there any difference between new and old engine's waterpump rotation whether it rotates clockwise or anti-clockwise? please If you have video or pics will be much better. Thanks,
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
01-09-2012, 03:24 AM | #2 |
Re: Q about serpentine belt
you have to change the water pump.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
01-09-2012, 05:09 AM | #3 |
Do you know which water pump can fit on the engine?
01-09-2012, 07:17 AM | #4 |
BAD BOW-Silverado XST
01-09-2012, 02:23 PM | #5 | |
I actually have a limit budget, so I prefer to buy brackets for newer engines. However, I just wanted to know what engine I can get brackets from that fit on my engine exactly without modifications. So the brackets that you have installed in your engine are from 91-95, right?
01-09-2012, 02:44 PM | #6 |
Is anyone running a setup like this without A/C and the big bracket that it uses? I'd like to go to a single belt, but don't have A/C and want to keep things as minimal as possible (crankshaft, water pump, P/S, alternator).
01-09-2012, 03:11 PM | #7 |
^^^You can get an A/C delete pulley that Doorman makes and put it in place of the A/C.
01-09-2012, 04:56 PM | #8 | |
I want something like what come from the factory. For example, I take (alternator, A/c, water pump, brackets,and etc...) from 350 engine 1992 and then fit them to my 1984 350 engine. Has anyone done something like that?
01-09-2012, 09:32 PM | #9 | |
It's 45 degrees here in Seattle too. Fahrenheit. I use my heater plenty, but have no need for A/C. Both of my last two cars I specifically looked for NO A/C models. |
01-09-2012, 10:29 PM | #10 |
Yes. Mine is off a 1991 suburban. Works perfectly. Have to use the a/c hoses off the burb and move the wiring around.
84 GMCummins 91 CCSB Dually american squarebody association |
01-10-2012, 01:39 AM | #11 |
Everything thing from the 92 will bolt to your 350. Brackets, water pump and accessories from a 4.3 will also bolt on. My setup is from a S10 Blazer. Here is a picture off all parts.
http://www.summitracing.com/parts/NAL-12497698/ Truck brackets don't have a provision for an air pump. One more reason, I like my setup. |
01-10-2012, 01:45 AM | #12 |
Windy Corner of a Dirty Street
Check out this thread in the FAQ section
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
01-10-2012, 07:55 PM | #13 |
I am running a serpentine setup with no A/C. It was on the motor when I bought it. One thing nobody has mentioned is you will have to flip your fan blade around when you do it, I wasnt sure the previous owner replaced the water pump so I put a new one on. Got one for a 1989 truck. Its a reverse flow pump. Your old alternator willl not work with the serpentine brackets. I have a 1985 truck. To use a newer alternator you have to use a 5 volt 85 ohm resistor in the trigger wire if I remember right. Here are a few pics of the setup.
01-10-2012, 08:52 PM | #14 |
Interesting A/C delete pulley. I've never seen one like that one.
01-10-2012, 09:41 PM | #15 | ||
I wouldn’t lean over that fan shroud while the engine is running with the blade on backwards!
01-10-2012, 09:50 PM | #16 |
http://67-72chevytrucks.com/vboard/s...d.php?t=481708
this is what I did it was the cheapest way I could figure out hope it can help you Posted via Mobile Device Posted via Mobile Device |
01-11-2012, 03:35 AM | #17 |
thanks guys
that is worth it. this is what i want 'experience'
