Old 01-11-2019, 11:24 PM   #1
p0508
Calling all vintage air/classic auto air owners
Hey all,
I'm trying to decide between vintage air and classic auto air. The main difference i see after reading through both the install manuals is with classic auto you have to cut out a pretty large chuck of the firewall but with vintage air you don't. I've also read that classic auto air cools and flows a bit more air than vintage.
I'd like to hear straight from the owners on this one. Tell me what you like and what you don't like about your respective system, and if any representatives from either company are on the forums, tell me why I should buy yours over the other.
-Drew
p0508 is offline   Reply With Quote
Old 01-12-2019, 12:02 AM   #2
flashed
Re: Calling all vintage air/classic auto air owners
I have Vintage Air and it blows Cold and Blows Strong , will use it on my next one too . Cant say about the others but Im sure they all work good . I used the Vintage Air Sure Fit system . And there is a member on here (or was) that worked for Vintage Air .
flashed is offline   Reply With Quote
Old 01-12-2019, 12:13 AM   #3
p0508
Good to hear, i've been leaning toward vintage air cause i dont want to cut out that middle chuck of my firewall..
Old 01-12-2019, 03:22 AM   #4
Metaldoc
Metaldoc's Avatar
Vintage Air Gen 5 sure fit kit works great and fit great.
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 01-12-2019, 09:36 AM   #5
shoveldug
I have put 2 vintage air systems in and have no complaints. Can’t speak for other systems.
paypal is dwl65101@yahoo.com
shoveldug is offline   Reply With Quote
Old 01-12-2019, 09:42 AM   #6
dfwright
dfwright's Avatar
I have Vintage Air and am very happy with it. The only thing I don't like, is that I can't turn the fan on and blow air without the heat or A/C running. I've put in a switch to bypass the compressor so I can accomplish this, but it should be built into the system. Sometimes I just want a little air moving, and I don't need the A/C running.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-12-2019, 11:09 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Calling all vintage air/classic auto air owners
Classic air is in my 56 and love it. Better fit than vintage air. No cutting and it used the stock defrost vents.
My 71 had the classic air motor bay kit for 134-a before the LS swap and it was great to.
They even put me on the catalog!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-12-2019, 11:35 AM   #8
shoveldug
Originally Posted by Shinysideup View Post
This thread is the same as all the ones you could read if you searched. I personally have used and like the VA brand.
Hopefully he will apologize for his actions.
Old 01-12-2019, 04:47 PM   #9
morepwr
Vintage air in 2 vehicles for me and they both fit and work perfect.
morepwr is offline   Reply With Quote
Old 01-12-2019, 05:29 PM   #10
weq92f
I've got VA and use their 4 dial controller.
dial 1 = fan
dial 2 = air vent selection
dial 3 = heat
dial 4 = cool
If dial 4 is turned all the way "off" the compressor never comes on.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-12-2019, 08:28 PM   #11
bigbadchev72
People know me
bigbadchev72's Avatar
I have the newer vintage air system in my 68. I shaved the firewall and used their blockoff plate as a template. It went in and works without a fit. The instructions are very detailed and leave no questions.
On the flip side I am installing an old air hurricane system in a 66 k20 for a friend and the instructions are absolutely garbage, looks like a 10 year old originally put it together and then photocopied it a thousand times so the pictures are super blurry and not detailed. Wiring schematic is even hand drawn.
That being said that there are a ton of options out there and everyone is gonna have their opinion. Most everyone has vintage air in their trucks because it is proven and work great IMHO.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 01-12-2019, 08:55 PM   #12
57larry
I have used VA several times, cool & heat great
57larry is offline   Reply With Quote
Old 01-12-2019, 10:13 PM   #13
leddzepp
Moderator
leddzepp's Avatar
If you aren’t restoring a factory system, VA is the way to go.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-13-2019, 12:25 AM   #14
Slowguy
I’m confused when I look at the va site. I see, at least on the forums, there lots of different configurations. It looks like the easiest are the vents that just mount below the dash. I prefer the factory look and don’t mind a little work. Is there a va kit that allows you to have a factory vent configuration in a non ac cab? One that would require me to drill holes in the dash and a square one in the center? I also have a factory Chevy ac/heat control that I picked up along the way hoping to use that to retain a factory appearance.
Slowguy is offline   Reply With Quote
Old 01-13-2019, 10:01 AM   #15
elf w/capital T
Vintage Air Gen 5 sure fit kit works great and fits good, you can install it by yourself, customize the hoses and locations, their customer service is good too! Troubleshooting is easy too
elf w/capital T is offline   Reply With Quote
Old 01-13-2019, 11:55 AM   #16
Slowguy
So when someone says “ac or non-ac cab”, are they referring simply to the holes made in the dash? Or are there other major differences?
Old 01-13-2019, 01:28 PM   #17
Metaldoc
Metaldoc's Avatar
No AC cab has no holes in the dash and doesn't have the vents. They use your old controls that need a modification, but easy
Old 01-13-2019, 02:05 PM   #18
darrellyates
Firewalls are also different. The factory openings thru the dash are different for an a/c vs. a non-a/c cab. VA will allow you to mix. I have done 2 trucks with Vintage Air. Both were non-a/c cabs that I put the factory outlets in the dash, both the rectangular vent over the radio, and the chrome housing with the round "balls" in them as from the factory (available as re-produced very economically).
Again, there are likely dozens of threads on this site regarding this. Most of them have covered everything discussed here.
Either will work well, and everybody has their preferences. I will say that from my observation, vintage air has more outlets for their products or that they are more widely used. Just my opinion...
darrellyates is offline   Reply With Quote
Old 01-13-2019, 04:09 PM   #19
my kids toy
I would like to know this as well...
my kids toy is offline   Reply With Quote
Old 01-13-2019, 04:30 PM   #20
darrellyates
Yes. Order the non-a/c kit, and then just get the factory vents from one of the vendors on here (GMC Pauls, LMC, Brothers, everybody has them).
Then, cut the holes for the factory vents in the dash, the rectangular one above the radio is the same in either kit. I made a template for the vents in the dash with a scrap original vent I got at Pull-A-Part... Cut of the back, held it up, traced and then cut. I then used paper and reversed it for the other side....
Here is what it should look like. If you call v/a and discuss it with them, they will even switch out the controller for a small fee (at least they did for me)...
Here is what it should look like. Non A/C cab, Vintage Air with factory style vents in the dash. I did smooth my firewall, but V/A comes with a block off kit that i didn't use...
Old 01-13-2019, 05:51 PM   #21
Metaldoc
Metaldoc's Avatar
My dash after the kit was installed in a non AC cab. I like the non factory side vents better.
Old 01-13-2019, 07:59 PM   #22
my kids toy
metaldoc, were did you get your vents ? they do not look as big as the ones darrellyates has.
Old 01-13-2019, 09:22 PM   #23
flashed
They should come with the kit , mine did .
Old 01-13-2019, 09:52 PM   #24
Metaldoc
Metaldoc's Avatar
Yes they came with the sure fit kit
Old 01-13-2019, 09:57 PM   #25
Metaldoc
Metaldoc's Avatar
I also shaved the firewall for cosmetics but I was able to shift it towards the center to gain more air flow through the side vent.
