Old 12-30-2013, 06:44 PM   #1
68c10owner
68c10owner's Avatar
1997 gmc speedo recalibration
My 2wd truck had 31/10.5/15`s on it when I bought it. I`m about to replace the tires and was thinking of going back to the stock 235/75/15 to get better mileage but I know they are shorter and will throw the speedo off. I googled it and read something about resoldering stuff in the VSSB but there has to be a easier way. I dont have alot of tools available and dont have money for a scanner. I have a $50 unit to check codes but I dont believe it will recalibrate the speedo. What can I do? will driving it with the speedo off effect anything? I mean will the computer think its going a certain speed and do something it shouldnt? I dont know much about these newer trucks so I`m still learning.
Anthony
68c10owner is offline   Reply With Quote
Old 12-31-2013, 08:59 AM   #2
speedygonzales
speedygonzales's Avatar
Re: 1997 gmc speedo recalibration
What makes you believe it was changed from stock ?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 12-31-2013, 09:56 AM   #3
400sbctruck
Gearheadefi.com has some info about that stuff.
400sbctruck is offline   Reply With Quote
Old 12-31-2013, 01:41 PM   #4
68c10owner
68c10owner's Avatar
because the tire size was changed for a taller tire and the speedo reads correct now. if it wasnt changed it would read slower.
Anthony
Old 12-31-2013, 01:41 PM   #5
68c10owner
68c10owner's Avatar
thanks I'll check it out. was hoping someone here would be able to help me.
Anthony
Old 12-31-2013, 05:00 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
I would recommend plugging a gps in and seeing what your speedo says vs the gps. Your tire sizes are fairly close. And the difference wouldn't be huge.
95 S_Trucker is offline   Reply With Quote
Old 12-31-2013, 06:03 PM   #7
68c10owner
68c10owner's Avatar
its about a 2-2.5" difference but I just got them put on and didn't notice if its off or not yet. Only put a couple miles on it. I will try the GPS and see if its off. If not then I'm good otherwise I found on the net that the dealer should be able to recalibrate the speedo if needed. Hopefully the stock size tires will help get some better fuel mileage. still going to do a full tune up Thursday.
Anthony
Old 12-31-2013, 06:19 PM   #8
95 S_Trucker
Most factory speedometers read slow. I put 285 75 16 on my truck where 245 75 16 and the speedo is accurate right now.
Old 12-31-2013, 06:23 PM   #9
68c10owner
68c10owner's Avatar
Every speedo I have GPS's has been off from the factory. When it says 55mph its actually 53mph. We'll see if its off. I heard the speedo being off could effect the transmission shifting, ABS, and the airbags if I'm in a accident. Just don't want any issues.
Anthony
Old 01-02-2014, 10:52 AM   #10
speedygonzales
Yes all speedo's are off by design. Slower than reading.
The only way to change the year in question(accurately) is by programming.
Pride and joy
Old 01-03-2014, 01:55 PM   #11
400sbctruck
On topic related thought-
Would a rheostat or pot on the pulse side act as an attenuator?
The real question is whether it is pulse code or pulse width i assume.
Obviously, this would only work for "slowing" speed if it would work at all.
Old 01-04-2014, 03:33 AM   #12
68c10owner
68c10owner's Avatar
So far the speedo appears to be correct. Guess the difference in diameter wasnt enough to mess with it too much. Rpm`s are up a bit but not too bad. Sure rides a hell of alot better and quieter inside too. Still has what feels like a slight tire out of round but cound be a drivetrain issue I`m working on. Need to rebuild the frontend and get a alignment and could use some new shocks too. Little bit at a time.
Anthony
