02-03-2020, 02:07 PM | #1 |
Crank pulley
This plate washer is in the way to get my crank pulley installed.
Is there any reason why I can't remove the bolt and plate washer and put the pulley on first and then re-install the bolt and a thinner washer? Should I just use the same washer? HT383 crate motor Is there a preferred method to holding the balancer in place to get the bolt re-torqued? thanks for any help |
02-03-2020, 02:12 PM | #2 |
Re: Crank pulley
Exactly what you need to do. Remove, install pulley and keep that thick washer. You can use a few longer bolts in the crank and a pry bar to keep the engine from spinning over to get your torque.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
02-03-2020, 02:49 PM | #3 |
Re: Crank pulley
It looks like the engine is not installed. You can use bolts in the back end of the crank to hold it still.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-04-2020, 10:38 AM | #4 |
Re: Crank pulley
thank you both for the help.
The motor is still in on the shipping crate, and I'm gonna keep putting accessories on it before the install. I did just learn how to link my build/help thread, I'm certain there will be more questions asked there, thanks again |
