Old 08-09-2016, 11:29 AM   #1
paintinx
paintinx's Avatar
door switch / dome lamps
Hej,
I am currently trying to repair the dome lights at my 79suburban.
Right now there are now light and also no voltage in the socket.
My way was:
I have found these little switch in the driver door frame.
is this the "ground"switch for the dome light?
does it work like a "breaker"?
i asume that I have to switch the (car) lights on and the
knob should be in the left / fixed position, right?
next: i have checked all fuses - but maybe - the fuse isnt there (under the
dashboard) - how is the fuse called???
(cigarette lighter is the same fuse as the HORN)
would be great to get some tipps
thx in advance, stephan
ps: i know the thread "http://67-72chevytrucks.com/vboard/showthread.php?t=481653"
paintinx is offline   Reply With Quote
Old 08-09-2016, 10:00 PM   #2
buffydores
buffydores's Avatar
Re: door switch / dome lamps
There should always be some voltage in this line. Sounds like a line cut or bad ground.
Old 08-10-2016, 02:58 PM   #3
paintinx
paintinx's Avatar
hello again - i got the solution today by trying something.
here for all users with the same question the whole story:
1st, I measured the electricity from the switch in the drivers door.
result=white cabel - it is GROUND
door closed - no ground, door open - ground
2nd, I opened the covers inside the drivers door, found some rust
and measured ALL cabels - and as a few thread describes - "cable
can be broken" - it is/it was.
(look at the photos I took)
3rd, I replaced all cables from drivers carpet till the B pillar
(there is a connector inside the b pillar - watch if it is ok and not "corroded"
4th, I got it
thx, stef
2 kids, 2 cars
Sub2k - 5.3 ltr vortec
Sub79 - 7.4 ltr big block
Das Schiff ist im Hafen sicher,
aber dafuer nicht gebaut.
Old 08-10-2016, 03:07 PM   #4
paintinx
paintinx's Avatar
another question re dome lights
what would be the best way to get two new lamps
for my suburban?
the older ones are very corroded ...
stef
2 kids, 2 cars
fuse
