Old 07-07-2003, 10:09 PM   #1
dion
72 Cheyenne
dion's Avatar
arggg!!! stranded
I've been having starter problems, they work fine for a few days and then crap out. I can't see to figure out what the problem is.
So today she was starting but made a little screech, but would start. So I stop at the Bank on the way home and yep you guessed it, when I went to start it the started wouldn't engage. I moved the flexplate around still nothing. So I had to get a tow.
What sucked is that the entire time I was trying to start it there was a ferd parked next to me with a couple guys sitting in it and then when the tow truck showed up yep you guessed it again, another ferd. A ferd towing a Chevy, what a shame. At least the ferd stalled when we went to take off, I think my girl made that happen
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-07-2003, 10:16 PM   #2
Class of 69
Class of 69's Avatar
Sorry to here about the starter problems....and a ferd towing it!!! Are you installing rebuilt one's?? They can be a real pain!! I usually rebuild my own, so I know what I have when it's done. Be sure to use a heavy duty solinoid, not a cheap standard one!! They can be the cause of more trouble than the actual motor
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-07-2003, 10:44 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
As far as your starter problems go.....
When i bought my truck, it would never want to start after it was hot. The starter wouuld turn over really slow, and make a god-awful grinding noise. Pretty embarsing when i was parked in a lot with people around, lol. I put 2 different starters on it, and the problem was still there. Then, when i got my motor rebuilt, i had the shop give me a new flexplate. Using the same starter, it completley fixed the problem. Also, you may want to buy a heat shield for your starter ($25 from Summit), and a starter brace. The starter brace keeps the starter from flexing by bolting the front of it to the engine block. The brace is available for $5 from any Chevy dealership.
Also, sometimes mine wouldn't engage, and i found that by loosening the starter and then tightening it back up again, it would engage and i could drive the truck.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-07-2003, 10:56 PM   #4
woodrow59
OzarkHillbilly in Atlanta
I agree with class,,,,,, if you're having starter problems, get a new one, not a rebuilt one. I had a '70 that I put 2 or 3 different "cheap starters" on and even put on a new flywheel. Still had problems. Took it to a guy that put on a new Delco-Remy and it was fine after that !!!!
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 07-08-2003, 01:14 AM   #5
krazy_texan
krazy_texan's Avatar
if you are running headers on the truck like me, then keep an extra sylinoid lying around because i burn through one about every four months and i bet you that i could replace one on a 350 in record time
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
