01-21-2008, 02:53 PM | #1 |
Post your brakes!!
I want to see your guys brake master cylinder locations(on firewall or under cab) and any details what you guys went with, tips, advice etc etc. It would even be a bonus if any of you s10 frame guys have brakes all squared away already. I think what I'm going to do is run the MC under the cap, with a dual diaphragm system and have a remote resivoir for easier maintenance. There was a vendor at the car show i went to today that helped us with this. He said we use the supplied bracket, mount it on the frame, then just bend the pedal through the floor where it needs to go.
01-21-2008, 10:33 PM | #2 |
Re: Post your brakes!!
i used an 85 full size blazer brake pedal,booster,and master. i would sugest you use the s 10 brake pedal,booster,and master. it's not hard to mount them under the dash plus you will have the proporshing valve witch you will need. i got lucky the p valve that i had from another s10. the bracket bolted right in the same place as the s10 one with the booster bolts. the lines lined up as well. don't have any pix but it's not hard just measure twice cut the hole once, and put your steering column in to make sure there will be no problems with them touching anywhere. have fun braking you ride
01-22-2008, 02:29 AM | #3 |
Would the s10 being manual make a difference? the 48 will be auto now. Other than the pedal being small? I guess i hadnt thought of that, the MC is already integrated into the s10 frame too....hmmmmm
01-22-2008, 02:44 AM | #4 |
Here are a few pics of the firewall mounted system that I used on this build. My other one has the power booster/master cylinder under the floor. I decided to go this route on this one for "ease of serviceability" since I plan on driving this one almost daily...................
01-22-2008, 03:19 AM | #5 |
Thanks a bunch for those pics, plenty of steering column to booster clearance? Also, what column did you go with? We were thinking Ididit or Flaming River one? What are you doing for pedals? buying aftermarket? Could you post up some pics of the other build for comparison? If we go the underfloor route we would use a remote reservoir, which would make it easy to service. Not a knock on you but i wanted to go underneath the cab for that really clean look, we have the s10 booster and MC already, so that would probably be the smarter way to do it.
01-22-2008, 03:27 AM | #6 | |
01-22-2008, 04:01 AM | #7 | |
01-22-2008, 04:15 AM | #8 | |
01-22-2008, 05:03 AM | #9 |
the reservoir would not be hidden unless you came up with an idea to hide it. Id much rather have a silver can(stainless with a hose going out the bottom) than a big brake booster and MC. I just went down and looked at the frame and booster. The booster mounts inside the cab so i think ill go that route, itll just be the MC on the firewall, which wont be so bad. And, the undercab deal was like 325 from the vendor but we found ones for 180 on ebay, but i dont wanna screw with that. I think s10 brakes all the way around, since the proportioning valves are already there and such. Ill just have to see if i can get the brake pedal to work and not have it in your lap.
01-22-2008, 12:13 PM | #10 |
I did something a little different on my dad's 52. We did a underdash unit. Here are a couple pictures.
Bernie |
01-22-2008, 01:52 PM | #11 |
I chose function over fashion for the underhood. I want it to look semi-factory. Not 1954 factory, but an updated GM factory. Here's a shot of mine:
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
01-22-2008, 03:30 PM | #12 |
I went with TCI's frame mount.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 01-22-2008 at 03:32 PM. |
