Old 08-27-2017, 11:59 PM   #1
farmer21
K10 suspension
I've looked at Offroad Designs Coilover kit. Looks pretty nice. Are there any other options out there.
farmer21 is offline   Reply With Quote
Old 08-28-2017, 08:02 AM   #2
Re: K10 suspension
I'm not familiar with a coilover kit. What K/10 do you have? When you say coilover I think of shocks. Is that what you mean? More info would help me help you.
Old 08-28-2017, 08:22 AM   #3
farmer21
Re: K10 suspension
It's a four link kit replacing all leaf springs. It looks like it will take a little bit of fabrication for the hoop towers but definitely doable. 1972 K10
Old 08-28-2017, 10:47 PM   #4
andrewmp6
Re: K10 suspension
Their kit is deigned for these trucks there is others but they are way more diy type stuff,Like http://www.ruffstuffspecialties.com/.../LINKPROD.html http://www.chassisunlimited.com/stor...html?mode=list
Old 08-28-2017, 11:37 PM   #5
farmer21
Re: K10 suspension
Is there such thing as a trailing arm bigger coil spring lift. I know there is a 1971 in Bakersfield with this setup
Old 08-29-2017, 12:12 AM   #6
andrewmp6
Re: K10 suspension
There is custom springs you can have made,And the type of suspension used depends a lot on how you will use the truck.A rock crawler and a desert racing truck are night and day on set ups.
Old 08-30-2017, 10:08 PM   #7
Re: K10 suspension
Ok, that's what I figured, but the "coilover" threw me off. Those are just shocks with coil springs over them. I built a 4-link rear suspension on a '95 K3500 for air bags. It was about hauling capacity and adjusting height, not race inspired.
Old 08-31-2017, 12:43 AM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
Re: K10 suspension
ORD's stuff is nice for sure. Fortify Offroad is another place building coil-over/link setups. They focus on the squarebody style, but the earlier isn't far off from it.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-31-2017, 12:56 AM   #9
farmer21
Re: K10 suspension
Is ORU still doing Conversions for older trucks?
Old 08-31-2017, 02:06 AM   #10
'63GENIII
'63GENIII's Avatar
Re: K10 suspension
Ive used some of RuffStuff's parts and the quality is unbelievable. Very close to DIY4X4 quality IMO. The kind of stuff you'd build a tank with. They're close by in Loomis.
FWIW, Ive used ORD alongside DIY4x4 and Ruffstuff in my 63" - 52" spring swap and while ORD does make some good parts, they don't come close to the build quality of the DIY and Ruffstuff hangers, plates shackles and hardware.
Not even close.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-31-2017, 03:02 AM   #11
andrewmp6
Re: K10 suspension
This is the kit hes talking about http://offroaddesign.com/catalog/Fro...Conversion.htm
Old 08-31-2017, 08:58 AM   #12
'63GENIII
'63GENIII's Avatar
Re: K10 suspension
That does look like a pretty slick set up.
Chris
'63 k15 long step
Old 09-01-2017, 02:48 AM   #13
andrewmp6
Re: K10 suspension
Yeah and the brackets are designed for these trucks so it takes a lot of guess work out of other kits.
