01-10-2014, 02:05 PM | #1 |
15" Rims with disc brakes ??
So the corner of the caliper rubs the inner rim.
Does anybody know the best way to fix this? It will spin but rubs the rim. I guess the two options are to grind down the caliper and or the rim. The caliper being easier I should start there, just wanted to see if anybody has solved this problem? The 18's fit great but I like the 15's better. Just ordered these MT's for the fronts. http://www.summitracing.com/int/part...6653/overview/
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
01-10-2014, 02:38 PM | #2 |
Re: 15" Rims with disc brakes ??
You don't post much info about your setup but if you are running the stock steelies with disc breaks in front they will not work, you would need a set of steelies from the 72-87 year trucks in order to work with disc brakes.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
01-10-2014, 02:59 PM | #3 |
Senior Moment
I'm running 15" car rallys and have the same problem. What I did was use a 1/8 inch wheel spacer and ground down the caliper. I dont like spacers but in this case its only an 1/8 inch and it made it so I did have to grind much at all. just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-10-2014, 03:18 PM | #4 |
I believe I have read that a 5/16" spacer will clear the caliper... grinding is the other option, remember if you grind your rims, also do the spare.
01-10-2014, 03:47 PM | #5 | |
This thread will show the way~!
01-10-2014, 04:28 PM | #6 |
20' Daredevil (Ret)
I would not grind the rims. You said they'll spin but rub, so it's only a minor clearance problem. Just grind a bit off the calipers. I did that a long time ago so I could fit 15s on my K20, and it's never been a problem. Dunno how thick the caliper castings are but apparently there's plenty of material there to start with.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-10-2014, 04:53 PM | #7 |
The answer is to use 71-87 15" rims. 70 and prior are drum brake wheels and they are tapered differently on the inside. 71-87 fit the stock disk brake caliper. If you are installing bigger than stock caliper or bigger than stock dia disk, then you will need aftermarket wheels. I wouldn't grind caliper or wheel to make it fit.
If you converted to 5 lug - 71-87 C10 wheels will work. If you converted to 6 lug disk - 71-87 K10 wheels are what you need. |
01-10-2014, 05:05 PM | #8 |
6 lug disk, CPP calipers.
there is lots of steel on the caliper corner so I will grind that down a bit and try it out. I would like to keep the oem 67 rims for sure. I put it on a spun it by hand and it left a small scratch all the way around. |
01-10-2014, 11:16 PM | #9 |
I'm running 14"x6" with a spacer on stock '72 disc brakes with no grinding.
01-10-2014, 11:47 PM | #10 |
I understand. Grinding will probably work fine - but just so you know, you probably wouldn't be able to tell the difference between a 7" K10 wheel and your stock 67 wheels visually. It might be worth a run through a local yard or two. But, sounds like it's so close to not rubbing already - so however you choose to go, hope it works out. I had a 66 - same issues, always bugged the crap out of me that the stock drum wheels didn't quite fit the newer calipers, ha.
