Old 01-09-2019, 01:28 PM   #1
SunSoaked
SunSoaked's Avatar
VSS/Dakota Digital
This fit several topics so I put it here for greatest response.
I want to install the DD VHX instrument panel. I have already had the 205 modified by ORD to use the 40 ppr vss.
Dakota says their guages work with any output of 2k ppm or greater.
Anybody know the conversion from ppr to ppm? Why's it always complicated!
SunSoaked is offline   Reply With Quote
Old 01-09-2019, 03:57 PM   #2
sweetk30
sweetk30's Avatar
Re: VSS/Dakota Digital
guy on my other site ck5.com just did d.d. dash unit in his crew cab 8.1/allison swap with 205 .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-10-2019, 12:02 AM   #3
Big Moose
Once you have the gauges installed and working it's easy to calibrate the speed, Probably not too critical what your ppr is.
The calibration is easily adjusted up or down after the initial calibration
Big Moose is offline   Reply With Quote
Old 01-11-2019, 11:48 AM   #4
1957 Chief
Proud Vet that loves the USA
Just like what the other guys said, it's easy once you get the truck moving. I think there are like 3 ways to set the speedo, and then there is also another function for you to fine tune the speed.
Bubba
1957 Chief is offline   Reply With Quote
