Old 03-25-2018, 12:49 AM   #1
Jotto82
Detroit locker
I want to switch to posi. Anyone have advice for installing a Detroit locker in a 14 bolt corporate rear end?? I’ll
Jotto82 is offline   Reply With Quote
Old 03-25-2018, 01:24 AM   #2
Matt Man
Matt Man's Avatar
Re: Detroit locker
A detroit locker is not the same as a posi like a trutrac. Are you going to be running the same ring and pinion?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 03-25-2018, 01:25 AM   #3
Myers horsepower
Myers horsepower's Avatar
Re: Detroit locker
Detroit Locker is defently different than a "posi" Detroit lockers are probably the easiest to install into a full floater 14 bolt corporate. It takes about a hour and half to install. Mine came with complete instructions.
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60.
1972 CST K5 350/th350/12blt,eaton posi/D44
1970 K10 SWB
1970 K20 350/th350
Myers horsepower is offline   Reply With Quote
Old 03-25-2018, 01:36 AM   #4
Jotto82
Re: Detroit locker
I just want both tires to turn when doing a burnout lol
Old 03-25-2018, 01:37 AM   #5
Jotto82
Re: Detroit locker
I want it as simple as possible!
Old 03-25-2018, 05:42 AM   #6
cadillac_al
Re: Detroit locker
The Detroit is the best and cheapest for a 14 bolt. I personally don't like lockers or posi in my snow buggies.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-25-2018, 08:04 PM   #7
Gdub310
Re: Detroit locker
A locker is great for off-road, and for dry pavement if you are willing to put up with some of the side-effects like the ratcheting noise and sometimes unpredictable behavior in turns. But for daily driving in a variety of conditions - rain, snow, ice - it definitely is not a good time. A limited slip unit would be a much better choice.
Gdub310 is offline   Reply With Quote
Old 03-25-2018, 09:24 PM   #8
Jotto82
Re: Detroit locker
Lol can I still do good burnouts? I know that sounds stupid but my kids likes burnouts. Will the limited slip be good for that?
Old 03-25-2018, 09:30 PM   #9
mongocanfly
mongocanfly's Avatar
Re: Detroit locker
I'm looking at tru trac for my 14bolt....not cheap though..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-25-2018, 09:42 PM   #10
Matt Man
Matt Man's Avatar
Re: Detroit locker
Yes a detroit locker and trutrac will make both tires spin. However, for your application I would buy a trutrac as you wont notice its there until its needed. As stated the detroit locker can be noisy at times and do the detroit "bang" which makes you think you blew up the rear end or driveshaft etc. On my 81, I notice tire wear is much faster with the detroit locker in the back of my truck.
Buy the trutrac, you wont be disappointed.
Old 03-25-2018, 10:16 PM   #11
GMC Guy
GMC Guy's Avatar
Re: Detroit locker
what about the Eaton Posi? I'm between that and the Truetrac
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-25-2018, 10:17 PM   #12
Jotto82
Re: Detroit locker
Great. Exactly the information I was looking for!
Old 03-25-2018, 11:02 PM   #13
Myers horsepower
Re: Detroit locker
HTML Code:
I'm running the Eaton Posi in my crewcab and love it!
If you just want to do burn outs, save your $$ for tires and put a spool in it.
1970 K10 SWB
1970 K20 350/th350
Old 03-25-2018, 11:52 PM   #14
Jotto82
Re: Detroit locker
If I’m going that far should I put new gears in too? Just do the whole deal at once?
Old 03-26-2018, 01:02 AM   #15
kwmech
Re: Detroit locker
I just put a tru-trac in the 14 bolt I'm going to install in my suburban, yeah, I choked on the price for a couple of weeks until I ordered it
Old 03-26-2018, 01:04 AM   #16
kwmech
Re: Detroit locker
If your choice is between the 2 get the tru-trac, it will perform the same...always, where-as the eaton will eventually have clutch issues down the road
Old 03-26-2018, 10:00 AM   #17
mongocanfly
Re: Detroit locker
jotto ...I'm of the opinion that if I tear into something I'm gonna replace everything....but....if there's nothing wrong with the gears I'd re-use them.....unless your wanting to change ratios..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-26-2018, 03:21 PM   #18
Jeepwm69
Re: Detroit locker
Installation should be the same. Both the Detroit and the trutrac replace the carrier.
The Detroit is not going to be friendly on the street.
Truetracs are great diffs, but not cheap. They don't wear out like Auburn or Eaton units with clutches.
If you want cheap and easy locker, you'd want a lunchbox like a Spartan, Aussie, or Lock-Right. They replace the spider gears and thus do not require setting up the gears like you have to do with a carrier replacing diff like a Detroit or a Truetrac.
The lunchbox lockers behave just like a Detroit on the pavement thought. Ratcheting noises and banging going around corners and your tires will wear faster.
Jeepwm69 is offline   Reply With Quote
Old 03-26-2018, 06:58 PM   #19
sweetk30
sweetk30's Avatar
Re: Detroit locker
best of both worlds here and try choking on this price .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-26-2018, 07:23 PM   #20
Jotto82
Re: Detroit locker
I’m not sure what ratio I have in there now. Seems like it’s pretty low though. I am on the same page with you about having it apart and just doing it all. None of this has to be done now. I’m just asking questions. I don’t even care to do burnouts to be honest. It was just how I explained what I wanted to achieve. I’ll stay away from the Detroit because that sounds like it’s more of an off road application as opposed to street wear n tear. Can someone tell me how I determine my gear ratios?
Old 03-26-2018, 07:57 PM   #21
mongocanfly
Re: Detroit locker
pull cover and count teeth is the most accurate...if your wanting burnouts, its a lot easier to spin one than two....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-26-2018, 08:12 PM   #22
Jotto82
Re: Detroit locker
I really don’t care about burnouts lol. I just want a posi rear end.
Old 03-26-2018, 08:25 PM   #23
dieseldawg142
dieseldawg142's Avatar
Re: Detroit locker
i daily drive my K30 crew with a detroit....it's not nearly as bad as everyone is making it out to be. if your a granny on the throttle, you'll never even know it's back there.
one downside is it is hard to do rightous donuts in the snow or mud, truck has a tendency to want to "push" in circles. but so what, awesome traction all the time, on road and off. only time it chirps going around corners is if i'm heavy on the throttle and have the wheel cranked hard over....
and with my bb and 4:56's, i love the way the ass end stands up if i hammer the throttle, 3 feet of rubber, 4:56's and a detroit, it launches hard for a 4 ton honey....
dieseldawg142 is offline   Reply With Quote
Old 03-26-2018, 10:21 PM   #24
bilfman
bilfman's Avatar
Re: Detroit locker
Same here I have run a Detroit locker in both a Dana 70 and 14 bolt daily driver. No issues, you have to know it’s in there to know it’s in there. If you know what I mean. I would put one in a 100 times over, they are tough and pretty much flawless.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-26-2018, 10:58 PM   #25
Matt Man
Matt Man's Avatar
Re: Detroit locker
Yep mine is fine as well for daily driving, I agree with both of these posts.
