03-26-2018, 11:12 PM | #26 |
Re: Detroit locker
03-26-2018, 11:25 PM | #27 |
Re: Detroit locker
you just need a spool if you are gona act like a fool QUOTE I just want both tires to turn when doing a burnout lol[
4x4k30 if trouble was money i would have plenty Last edited by 4x4k30; 03-27-2018 at 12:42 AM. |
03-26-2018, 11:51 PM | #28 | |
Re: Detroit locker
Personally, I would only install a Detroit locker in a 4wd, this is because if you have one tire off the ground the detroit locker will always spin both tires no matter what which is what you want if you wheel your truck hard. The truetrac on the other hand will only spin both tires if they're both on the ground and one tire loses grip. Which is why I would recommend a truetrac on a 2wd truck. You can get a truetrac to spin both tires if one is in the air if you lightly apply the brakes. The detroit locker and truetrac are fantastic units, I have a detroit in the rear of my 81 and a truetrac in the front. Both have no clutches to wear out and take no additives, just plain gear oil. Here is a video on what the bang kind of sounds like, even though this is a cheap spartan locker watch at the 1:38 mark. https://www.youtube.com/watch?v=Mi7ze7149HE
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
03-27-2018, 12:46 AM | #29 |
Re: Detroit locker
Not true, the detroit locker is not a complete unit in the 14 bolt where-as the tru-trac is. You use the existing carrier and take apart the halves, remove the spider gear assy and put in the locking assy. Bolt it back together with the ring gear and remove the holding bolt.
03-27-2018, 06:50 AM | #30 |
Re: Detroit locker
03-27-2018, 06:54 AM | #31 |
Re: Detroit locker
I do have 4WD so I guess I can just pick one. I gotta look at my gear ratios and I will probably just buy everything and then build it all at once. I appreciate all the explanations.
03-27-2018, 10:58 AM | #32 |
Re: Detroit locker
the detroit "clunk" i find is more noticeable on lighter trucks than on heavier ones. i can't ever recall hearing it in my crew, but got it a couple times in my K5
there is a lot of backlash with the detroit, but in no time you will adjust your driving style to accommodate it and then you won't even notice |
03-27-2018, 11:18 AM | #33 |
Re: Detroit locker
I found out years ago how to reduce the severity of the detroit when I had the locker in my wrecker snap into itself on a stretched out turn on a mountain road with a full load on the back. Talk about squirrelly at 50 mph. Anyways I drained the diff and pulled the cover thinking I had broken something but didn't. When replacing the oil I put in 2 quarts of Reline Shock Proof and 2 quarts of regular 85/90. Never had that clunk again and it was much quieter.
03-27-2018, 01:29 PM | #34 | |
Re: Detroit locker
Had to look into that a bit as I've only done Dana/Spicer Jeep axles. Looks like the 14 bolt carrier is heavy enough to reuse so the Detroit is just a heavy lunchbox style for that axle. Learned something new. As for on the street use, I'd still go with the Truetrac. I have a Truetrac in the rear of my green Jeep. Invisible on the street, and unless you have a wheel in the air it performs just like a locker. I have lockrights front and rear on my tan Jeep. They rachet and bang occasionally going around corners, but if you stay off the gas in a turn they usually don't make much noise. They do NOT like it if you have even a couple of PSI difference between the two tires on the axle. I have a Powertrax no-slip in the rear of my other tan Jeep. It's about the same as the lock-right, just doesn't make the noises. I would 100% go with the truetrac for a street driven truck. Buy once, cry once. |
03-27-2018, 05:46 PM | #35 | |
Re: Detroit locker
03-27-2018, 06:47 PM | #36 |
Re: Detroit locker
" buy once cry once. ".....so true ...so true
03-27-2018, 10:57 PM | #37 |
Re: Detroit locker
Been running a Detroit Locker in my 85 K20 (14 bolt transplant from a CUCV) for two years. Have yet to hear/feel any clunk or lockup.I know it's working because it leaves a nice parallel set of lines of black rubber when I hammer it. I am completely satisfied with it.
03-28-2018, 11:28 PM | #38 |
Re: Detroit locker
So if I decide on trutrac do just choose the gear ratio I want? Sounds like that’s a complete unit. I think I have 4:56?gears now but I think 4:10 might be bettter. Any options on what has been effective for them? Finished product is a low end torque power house. Motor has been completely rebuilt about10k ago so I’m thinking get the rear end setup how I want it then throwing in a nice loping cam and a decent top end kit. 350 400 HP and proper gearing and I’ll have a beast.
03-29-2018, 12:46 AM | #39 | |
Re: Detroit locker
03-29-2018, 01:40 AM | #40 |
Re: Detroit locker
and here ya go on the gear calculator...
http://www.csgnetwork.com/multirpmcalc.html
03-29-2018, 07:07 AM | #41 | |
Re: Detroit locker
Removing the pinion for a gear change changes the hole ball game as far as gear set up. Last edited by homemade87; 03-29-2018 at 07:15 AM. |
03-29-2018, 05:04 PM | #42 |
Re: Detroit locker
there is a carrier split for gear ratio's . you need to know what you have or are swapping to so you can get the correct one.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-29-2018, 07:33 PM | #43 |
Re: Detroit locker
Yes that was what I was asking. An earlier post made it sound like it was essentially a complete unit with gears. I probably just read it wrong.
03-29-2018, 10:46 PM | #44 |
Re: Detroit locker
i have a detroit in my 83. it has a 14ff 4.10 gears and 680hp. honestly its not bad at all. barely notice it. you can tell its there, but mainly on fast turns from a stop. Definitely would reccomend.
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz 680hp/720ftlbs of NA fun |
03-29-2018, 11:14 PM | #45 |
Re: Detroit locker
04-04-2018, 10:29 AM | #46 |
Re: Detroit locker
I like my Detroit but it does require some getting used to ESPECIALLY in slippery conditions! Not the best in snow...can get a little tricky till you get used to it.
Read the safety disclosure if you go that route. Sounds like you have an open carrier which is required with the Detroit. Sounds like your leaning towards something else anyway just wanted to put this out there.
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
