Old 11-12-2018, 04:48 PM   #1
shearjs
shearjs's Avatar
Suburban A/C
I have a 72 Suburban that I’ve been working on over the past year. It has factory front/rear air conditioning. I’m swapping over to a LS this winter and am considering upgrading to a Vintage Air unit up front to clean up the firewall and under dash a little in the process. I’d like to keep air in the rear as well for the kids if possible. Does anyone have any experience of converting an evaporator (rear unit) from R12 to R134a?? Thanks for looking and for any recommendations or suggestions.
shearjs is offline   Reply With Quote
Old 11-12-2018, 10:03 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Suburban A/C
A replacement expansion valve is readily available for the rear unit. It should be adjustable if it isn't getting cold enough.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-16-2018, 08:23 AM   #3
FLYNAVY30
Re: Suburban A/C
I did the LS/Vintager Air swap in my '72 as well. I can tell you that the front unit alone will not be enough to cool the entire truck. Getting the rear unit to work with the VA is still on my list of things to do, but I don't have the 3rd row seating, nor do I have kids, so it hasn't been a priority. The VA unit will "cool" the front, even in the middle of summer, but it certainly doesn't work as well as the A/C in a new SUV. That likely has more to do with insulation and window seals in modern trucks compared to our 50 year old covered wagons.
FLYNAVY30 is offline   Reply With Quote
Old 12-04-2018, 06:08 PM   #4
HSRACER
HSRACER's Avatar
Re: Suburban A/C
I have the exact combination your are describing and it works great. I left the rear unit alone and it works ok. If you can get an adjustable expansion valve I would do that.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
