Old 06-21-2019, 09:45 PM   #1
diveplane
ok my clutch is making a squeak
its not the pedal inside cab its coming from the piston inside clutch housing pushing on the clutch plate, would blasting some wd be ok in the hole to try
get rid that squeak, or replace whole clutch system slave and master cylinders?
diveplane is offline   Reply With Quote
Old 06-22-2019, 08:53 AM   #2
Re: ok my clutch is making a squeak
Sounds like you need a new throwout bearing.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 06-22-2019, 11:02 AM   #3
diveplane
i had all that redone new clutch and bearing its the slave cylinder piston making the squeak , see if i can try some wd in there.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
