Old 06-22-2019, 08:54 PM   #1
diveplane
correct part number?
for temp sending unit on engine block with 1 green wire to gauge in dash
i did the ground test and it pegged to hot, said to replace the sending unit.
V6 LB 4 94
diveplane is offline   Reply With Quote
Old 06-24-2019, 10:47 PM   #2
shifty
Questionable
shifty's Avatar
Re: correct part number?
Best I can do is hit GM catalog. It's listing 25037332 as the p/n but You should look at a pic of that part number on Amazon to confirm it's the same. It says it's compatible with 2-wire or 1-wire, but I can't confirm this is your part so don't blame me later
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-29-2019, 09:17 PM   #3
diveplane
thx
