Old 07-01-2019, 01:45 PM   #1
Jeepwm69
Adding transmission cooler, how are yall mounting them?
Have a Hayden 679 transmission cooler. https://www.summitracing.com/parts/h...stionsanswers/
Looks like my best bet mounting it will be to use the two small screws holding the condenser in place (will have to drill one hole in the mounting plate on the new cooler), but how do I support the other end?
Are yall running these things ziptied to the condenser or fabbing up a mounting plate for the other end of the cooler? I'm worried about the cooler rubbing/vibrating against the condenser, eventually causing a leak in one or the other.
Jeepwm69 is offline   Reply With Quote
Old 07-01-2019, 02:14 PM   #2
Stormin08
Stormin08's Avatar
Re: Adding transmission cooler, how are yall mounting them?
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
something like this, with a piece of rubber between may work...i personally prefer to make a bracket or mount back to the core support.
Stormin08 is offline   Reply With Quote
Old 07-04-2019, 10:06 AM   #3
I just run the factory set-up. But on trucks I added an aftermarket cooler, such as my '72, I make brackets to hold it out in front so the other components can get their air.I'd think one would heat soak the other if fastened to one another.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling)
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
