08-06-2020, 01:49 PM | #1 |
Vacuum gauge options for a 66?
Ive been looking at different threads like the one below and seen that some of the oldsmobile vacuum gauges can be modified but I have no idea which gauges might be worth looking at that will be compatible.
http://67-72chevytrucks.com/vboard/s...ch#post4818388 Anyone have a few options that they can share? I was going to plan to buy the decal set to redo my cluster and thought I would make use of the left and right spots that are blanks now. |
08-06-2020, 11:19 PM | #2 |
Re: Vacuum gauge options for a 66?
Early 60's Pontiac, Chev, and Olds console tachs are a nice fit. They are often on ebay, but nice condition ones are starting to get a little pricey, but not too bad. Here's one - it's been a little while since I did it, but pretty sure this is what I did my vac gauge conversion with. https://www.ebay.com/itm/60s-Pontiac...wAAOSw3dVfHt~p
08-07-2020, 09:18 AM | #3 |
Thanks Jocko! Ill do some snooping on ebay for 60 to 67ish I guess year range for all 3. Ive seen some that are for Air vs Vacuum too. I need to learn more on what the air gauge was for.
08-07-2020, 09:23 AM | #4 |
Here is a Pontiac one I put in my Suburban way back in 2002.
08-07-2020, 10:27 AM | #5 |
Looks great! So is $100 about what to expect on a pontiac vacuum gauge?
Interesting tach with the stem, so you set your red line with it I guess? |
08-07-2020, 05:27 PM | #6 |
Cost of the early 60s GM vac gauges is primarily driven by the condition of the chrome cup housing, so if you can find one that works, but with a crappy housing (which you won't need) you can get a good deal. Doesn't matter if Pontiac, Chev, Olds etc, all have the same guts, just a different types of detached face plates with a mfgr name on it.
08-07-2020, 05:28 PM | #7 |
08-08-2020, 09:22 AM | #8 |
08-08-2020, 01:22 PM | #9 |
Whats the best way to bench test the vacuum gauge before installing it?
08-09-2020, 10:16 AM | #10 |
08-09-2020, 11:25 PM | #11 |
