Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-10-2018, 03:01 PM   #1
stacey_65
HEI ignition module
Hey guys, I have a 85 c10 with the H vin and a 305. I am building a 350 and purchased a billet HEI distributor. The billet distributor has a 4 pin module and the stock HEI has a 7 pin Module. Can I rewire so the 4 pin will work? What is the major difference in them? any help would be great Thanks.
stacey_65 is offline   Reply With Quote
Old 04-10-2018, 05:58 PM   #2
ray_mcavoy
Re: HEI ignition module
The 7-pin modules are used in applications where the ignition timing is controlled by an ECM. The distributors that use the 7-pin modules do not have any mechanical or vacuum advance mechanisms.
The 4-pin modules are used in distributors that do have mechanical (and usually vacuum) advance. The power feed wire (typically a 12ga pink wire) that plugs into the connector on the cap is the same and can be used to power the replacement distributor. Any remaining connectors (except for maybe a tachometer connection) that used to plug into the old distributor will be unused. And you can probably eliminate whatever ECM and wiring was associated with the old distributor.
ray_mcavoy is offline   Reply With Quote
Old 04-11-2018, 10:39 AM   #3
stacey_65
Thanks for the info.
