Old 07-30-2016, 05:14 PM   #1
clockdoc
clockdoc's Avatar
Question Clogged Condensate Drain on 1978 C10
Hello folks. I recently got the AC on my '78 C10 Custom Deluxe working (was dead when I bought the truck in February). It's cooling well but today, in a heavy rain, I noticed what I thought was rainwater leaking onto the passenger-side floor. During a second trip later in the day, and after the rain had stopped and the floor had dried, I saw the same thing happening. I'm thinking that the condensate drain is clogged, allowing the water to rise high enough in the evaporator box to overflow and leak into the cab.
Now my problem is finding the drain to open it up! I was naively expecting to find a hose exiting the lower extremities of the box, and had visions of a shot of compressed air clearing it. I have yet to find it.
Any help will be greatly appreciated.
Clockdoc
clockdoc is offline   Reply With Quote
Old 07-30-2016, 05:40 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Clogged Condensate Drain on 1978 C10
I believe there's not a hose. It's a huge floppy piece of rubber on the bottom of the evaporator box.
http://www.classicindustries.com/pro...ts/ap5002.html
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 07-30-2016, 05:46 PM   #3
clockdoc
clockdoc's Avatar
Thanks Hatzie. Where is it located?
Old 07-30-2016, 06:36 PM   #4
clockdoc
clockdoc's Avatar
Sorry Hatzie! My question was a stupid one! You said on the bottom of the box. I have felt all around the bottom as far as I can reach and can't feel anything like that. Would you think that, if I drill (very carefully and with a pin vise) a small hole in the box so that I could apply a little air pressure,, I might be able to clear the blockage?
Clockdoc
Old 07-30-2016, 06:42 PM   #5
hatzie
Moderator
hatzie's Avatar
It should be right on the seam. There may only be a little slot.
When I pulled my 1976 AC box off the firewall I found a bunch of leaves and dirt in the bottom.
Old 07-30-2016, 06:58 PM   #6
clockdoc
clockdoc's Avatar
Thanks. I'll look again.
Old 07-31-2016, 04:59 PM   #7
clockdoc
clockdoc's Avatar
Finally found a picture of the bottom of the evaporator box (Attached). I've added a note to the pic to hilite the drain. It is a 3/8 to 1/2 inch hole--no tube--no flap, and it is very difficult to get a hand on. Was able to access it from beneath with a right-angle pick. When I did, I got a face full of water! All is well now.
Clockdoc
Old 07-31-2016, 05:54 PM   #8
hatzie
Moderator
hatzie's Avatar
There you go. They apparently improved it from 76. My 76 had a dirt and leaf filled 3/4" long 1-2 mm wide slot between the halves. I was tempted to drill a 3/8" hole.
Old 07-31-2016, 06:03 PM   #9
clockdoc
clockdoc's Avatar
Thanks for your help Hatzie
