03-26-2020, 09:38 AM | #1 |
What needed hardware, torque converter to flex plate
What hardware do I need to hook up my torque converter to my flex plate, I'm pretty sure a bolt, lockwasher and nut but, and what about a washer on the bolt first, also is this specific hardware for this hookup.
Thanks Nick NGN |
03-26-2020, 09:52 AM | #2 |
Re: What needed hardware, torque converter to flex plate
Most torque converters (I'm going to assume TH350) have threaded holes for the bolts. They are 3/8" coarse thread 1/2" long -
https://www.classictransmissionsolut...4aAibBEALw_wcB Or if the holes are unthreaded then these bolts with nuts are what you need - https://www.classictransmissionsolut...AaAml4EALw_wcB
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
03-26-2020, 09:54 AM | #3 |
If the nuts aren't welded to the tc (torque converter) you will need the 3 nuts and 3 bolts. I've never used washers or lock washers and I don't think they come in the kits you can buy for hw.
Not a bad idea to throw some blue loctite on the bolts |
03-26-2020, 11:08 AM | #4 | |
A friend years ago put hardware store grade 5 in his and sheared them while doing a burnout. Amazon will bring them to you. https://www.amazon.com/Spectre-Perfo...5235231&sr=8-6 |
03-26-2020, 04:29 PM | #5 |
Notes for my 71 C10 with 402/400TH. The bolts are original:
Ensure the converter spins freely until it’s mounted onto the flex plate. If the torque converter is seated correctly after that transmission has been mounted to the engine block, then there should be an approx. 1/8” gap between the contact points on the converter and flex plate. Pull the torque converter forward to the contact points, ensure the torque converter spins in this position and then mount it. The torque converter mounts to the flex plate using three (GR 5) 9/16" flange bolts. The bolt threads are 3/8-16 x 9/16. NOTES: One bolt is stamped "TR" and the other two are stamped "RBM". The bolts were torqued to 40 ft. lbs.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-26-2020, 08:20 PM | #6 | |
Thanks NGN Nick |
03-27-2020, 12:23 PM | #7 |
I'm not sure what you mean, can you take a picture? The TC should go on smoothly, you jiggle and spin a little bit until you feel 2-3 clicks. When it's on right you'll barely be able to put your finger (if at all) between the housing and back of TC from underneath.
03-27-2020, 03:35 PM | #8 | |
Thanks NGN Nick |
03-27-2020, 08:40 PM | #9 |
Nick you should be able to spin the converter even after it is engaged with the oil pump lugs, which are the squares you are talking about. The input shaft should spin freely all the time. The TC will move fore and aft even while fully seated. I would use the correct bolts, just to be safe. They are grade 5 and flanged, as Tony stated. Hope this helps.
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-27-2020, 09:44 PM | #10 |
If you cannot spin the TC you have more problems then what hardware to use. You need to get it looked at by someone that works on transmissions.
03-28-2020, 02:33 PM | #11 | |
Posting pictures is easy. Select Advanced mode if necessary, select the paper clip icon (attachments), select your picture, upload and save.
03-28-2020, 05:54 PM | #12 | |
Nick |
