11-13-2019, 05:26 PM | #1 |
Clearance specs for a 350 casting # 3970010 2 bolt?
I am looking for a resource for the 350 I have that gives main and rod bearing clearance specs needed for a rebuild. I have an engine that I pulled and stored a few years and with the help of a friend we were going to use some plati gauges and see where things are with this engine as we go through it.
Anyone have a resource for specs on this engine? So far Ive found this http://www.v8s-series.freeservers.com/sbc.htm |
11-13-2019, 05:46 PM | #2 |
Re: Clearance specs for a 350 casting # 3970010 2 bolt?
Lots of common specs there but nothing specific.
Try this link. https://www.enginelabs.com/engine-te...ng-clearances/ |
11-13-2019, 06:00 PM | #3 |
The standard spec for a stock 350 Chev is .0025". I'm happy with anything between .002 and .003. My last one in my truck was at .003 and I debated if it was too much but my oil pressure is always too high for my liking. I guess my engine must have a high performance oil pump but I can't tell by looking at them.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
11-14-2019, 12:17 PM | #4 | ||
"I ain't nobody, dork."
That casting number is the most common 4" bore block that GM ever made.
Depending on your use, the clearance could change. High performance and racing engines usually use clearances a little loose to compensate for higher oil volume and pressures. For a stock rebuild I shoot for between .002 and .003, trying to get right around .0025. Gary
