Old 03-19-2009, 11:17 AM   #1
americanmusc1e
americanmusc1e's Avatar
700r4 lockup wiring
I'm installing a 700r4 in place of my old th350,
for the lockup wiring can i run a toggle switch and a brake switch and forget the pressure switch and vacuum switch??? I have an '87 trans out of a camaro and it has a square looking plug with three pins in it, which is power, which is ground and what is the other one for?????
thanks in advance
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-19-2009, 12:11 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: 700r4 lockup wiring
You have to have the TV cable, no matter what.
texanidiot25 is offline   Reply With Quote
Old 03-19-2009, 12:55 PM   #3
Indyuke
Yes, you can run a toggle along with the brake switch instead of a pressure switch. But why? It's much easier to wire up a pressure switch, plus it's much nicer to drive that way. Don't have to think about it.
And you don't absolutely need a vac switch. I put one in mine, but bypassed it the first day.
Indyuke is offline   Reply With Quote
Old 03-19-2009, 01:47 PM   #4
americanmusc1e
anybody know witch one is the "A" pin and witch one is the "D" pin?????
-- Josh
Old 03-19-2009, 02:12 PM   #5
americanmusc1e
which pin do i run the 12 volts to???? and which do i ground???? and what is the third one for????
-- Josh
Old 03-19-2009, 03:38 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Ill look it up this evening if no one els jumps in.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 03-19-2009, 05:17 PM   #7
michael bustamante
michael bustamante's Avatar
the plug should be labled which is which on the underside
1967custom
michael bustamante is offline   Reply With Quote
Old 03-19-2009, 05:26 PM   #8
cparman
sharp as a marble
the plug will be labeled. If I remember correctly, it will be the terminal in the upper left in your picture. I have a brake light switch, and a toggle, I did it this way so when I am poking along, and the engine is turning too few rpm, I can unlock the converter and eliminate the chuggle in the engine.
cparman is offline   Reply With Quote
Old 03-20-2009, 08:13 AM   #9
Andy4639
Old member
Andy4639's Avatar
I have mine just hooked up with a toggle on the dash. I bought the vacuum switch but just did away with it. It want lock up under 45MPH no way with the B&M kit. I assume you have the internal wiring done already to the transmission for this. I had it done while they built the transmission.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-20-2009, 03:39 PM   #10
americanmusc1e
thats how i'm going to do mine except i'm adding a brake switch too
-- Josh
Old 03-20-2009, 08:00 PM   #11
Andy4639
Old member
Andy4639's Avatar
Why do you want a brake switch. Mine works fine even without it.
Old 03-20-2009, 08:12 PM   #12
Indyuke
Americanmuscle, GENERALLY, power goes to your (A) pin, top left on your pic. Ground is bottom left on your pic, I believe it's (D). And (B) is top right, part of the tranny overheat circuit. The reason I say generally is because GM had like 37 different ways they wired up the TCC. So double check.
If you want to control the TCC with a toggle switch, run power to (A) through a toggle switch, and put a jumper between the other two contacts.
The torque converter will lockup only when the tranny is in fourth AND you have the toggle flipped on.
Wire it up like this without the toggle and the converter will lock up every time it shifts to fourth gear. Hope this helps.
Old 03-20-2009, 10:05 PM   #13
americanmusc1e
in case i forget to flip the switch when i have to slam on my brakes
-- Josh
Old 03-21-2009, 12:21 AM   #14
Indyuke
I think what andy means is, if it's wired to only lock up in fourth, as soon as you slam on your brakes, the transmission downshifts and the torque converter unlocks. Then when you get going again it upshifts and locks up again. Don't need a brake switch.
Old 03-21-2009, 05:03 AM   #15
Andy4639
Old member
Andy4639's Avatar
Correct if the truck is ever out of fourth gear it want ,Shouldn't lockup at all. I can even back up with the switch on.
Old 03-21-2009, 09:45 AM   #16
LEEVON
LEEVON's Avatar
If you don't want to mess with a switch, it's only slightly more difficult to put in a vacuum switch and brake cancel switch. I found them to be plentiful at the junkyard and free, I believe I pulled my vacuum switch from a K5, along with a tiny blue vacuum booster. 12v from pin A to the brake cancel switch, then to the vacuum switch and you're all set.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-21-2009, 09:58 AM   #17
americanmusc1e
thanks guys
-- Josh
Old 08-04-2009, 08:30 PM   #18
68_c10_on20s
68_c10_on20s's Avatar
Im kinda in the same boat and need some advice.I am going just the opposite route and need help wiring up the 700.My truck is a 93 model and it had a v6 with a 4l60e tranny I had a 350/700 ive installed and need to wire up the lockup now.The 700 only has 3 wires going to it and the e trans had 12. I still have the cpu hooked up only becouse im using the in tank fuel pump with a regulator on a carbed motor.Now I cut the plug off the e-tranny and ran a test light on all wires and they were all hot with the key on???? there was however 3 wires that looked the same color as the wires for the 700 plug but I dont wanna burn anything up so im looking for advice before I do anything.Heres a few picts I took with my cell to kinda help out.
http://i150.photobucket.com/albums/s...1/hoopty/3.jpg
http://i150.photobucket.com/albums/s...1/hoopty/2.jpg
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 08-04-2009, 10:51 PM   #19
shortbed70
shortbed70's Avatar
Hey that pic looks familiar I think its mine. I have a pressure swith tapped into the servo cover on the right side of trans and everyone is right about the wiring,top left a lower left d ,a=+,d+-. I have a pos. wire from a to switch and from other side of swith to fused battery sorce and ground to frame. locks up shortly after 4th gear. Some trans are different but if you do some research there are several kits to do this.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-04-2009, 11:26 PM   #20
americanmusc1e
just kidding,
this is a funny time to bring this up!!! my 700r4 is at the transmission shop because it started leaking around the front seal area, So I took pictures of how it was hooked up when I took the transmission out. BUT MY BROTHER DELETED ALL THE PICTURES I TOOK!!!! so I will have to look it up again.
the inside pin is not used. and one pin should be grounded and one needs a hot wire for lockup.
I'd recommend not using your computer, and hooking the lockup to a toggle switch. you don't need a brake switch or a vacuum switch, and it will lock up in 3rd or 4th gear.
I'll look it up again soon (probably Sunday), right now I'm working 13hr days baling hay and I don't have much time
-- Josh
Old 08-04-2009, 11:29 PM   #21
americanmusc1e
yeah sorry, I borrowed someone's picture. I don't remember who's it was
-- Josh
Old 08-04-2009, 11:41 PM   #22
jojo
printing is my trade
jojo's Avatar
Haha it is an old thread but I'm glad ya'll dug this old thread up anyway because I just had my 700r installed by the tranny shop and I got questions. The shop didn't wire anything nothing is plugged in accept the speedo cable and the tv cable. And it runs okay.
Am I causing damage by not having it wired?
Why would I want it to lock up?
I've had it up on the highway and it seems to stay in 4th so why would I want it to not lock up (ie switched)?
You mentioned it locks up in 3rd or 4th, is that determined by the shop that rebuilt it?
What is the purpose of the brake or vacuum switch and is that the 3rd connection on that plug?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 08-04-2009, 11:41 PM   #23
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
hope this helps...
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-04-2009, 11:54 PM   #24
americanmusc1e
some say that you are not supposed to drive in 4th without a converter lockup (something to do with the tranny overheat problems since the 700r4 was designed to be locked up in 4th gear)
when you lock it up you will get better mileage because the engine and transmission are "locked" together. if its not locked up the converter will slip and you will waste some mileage, usually when the converter locks up in 4th you will drop 400-500rpm
all 700r4's should lock up in 3rd and 4th (I think, somebody correct me if I'm wrong)
the third connection on the plug powered a transmission overheat warning light (or gauge) when used in the factory application.
-- Josh
Old 08-05-2009, 01:19 AM   #25
68_c10_on20s
ok so let me get this straight outa the 3 wires going to the tranny only 2 are needed if you have no gauge?This is my other question if you want it to lockup then why not just have a wire thats hot when the key is on? Ive had a few 700s in older trucks and never had a toggle switch but the tach always showed the drop in rpms on hwy speed.But then again ive always had the shops do the work too.
Now again I had a 94 and when i was on the freeway and had the cruise on if i tapped the brakes to turn the cruise off it would disengage the lockup i do know that.I am assuming thats what the brake switch it for right?
This has got me boggled and confused but it should be very simple right?
Heres another question to throw in the mix i do not have my kick down cable hooked up yet since i just got the truck running and when i leave off the line easy it goes thru all the gears very fast once i get this hooked up and adjusted right it should hold the gears longer right?
btw i took a pick of the plug and labled the wires now just witch ones to wire up to what?
http://i150.photobucket.com/albums/s...1/hoopty/4.jpg
