02-11-2017, 11:08 PM | #1 |
Ever had to install a belt kit on a 1990 GMC?
I was just planning on changing my serpentine belt as some routine maintenance before I get into trouble and noticed on a parts website that they offer a belt kit which includes not only the belt but the tensioner and idler pulley.
While I have had no belt noise or problems should all these parts be replaced as my truck has 110,000 miles on it? I know idler pulley bearings wear and the tensioner may lose strength but has anyone had to replace the tensioner and idler pulley? Thanks for any help. |
02-11-2017, 11:32 PM | #2 |
Re: Ever had to install a belt kit on a 1990 GMC?
I wouldn't change it. I've had to change the pulley before but only after it started squealing. The aftermarket ones are not as good as OEM. Like the old adage - if it's not broken, don't fix it.
Mike |
02-12-2017, 09:23 AM | #3 |
The One And Only !!!
I had to replace the tensioner and pulleys on mine at 63K, if you can get the belt with tensioner and pulleys as a "kit" cheaper than buying everything separate, buy the kit and shelf the pulleys for when you do need them.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-12-2017, 10:20 AM | #4 |
Registered Truck Offender
240,000 miles (3rd engine) 4th belt, SAME idler and tensioner.
When they go,,, they let you know with prejudice. I have only ONCE had one actually 'fail' and need replacing to get home. Otherwise they are kind enough to let you know it's time for replacement weeks, if not months in advance by starting to be 'noisy' in the morning when you first start it.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
