Old 02-12-2017, 05:23 PM   #1
65standard
65standard's Avatar
Advancing ignition timing on 5.7 vortec
I have a 1996 Cheyenne with a 5.7 vortec, 5-speed, and 3.42 locker rear. I was wondering if I can physically advance the ignition timing by turning the distributor. Or can it only be adjusted through programming?
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-12-2017, 07:29 PM   #2
cam.man67
cam.man67's Avatar
Re: Advancing ignition timing on 5.7 vortec
Nice truck! Nope, no dice on advancing with the distributor. The ignition module takes the signal from the crankshaft position sensor and only sends a charge as each cylinder reaches TDC. Turning the distributor only moves the cylinder contact away from where the rotor tip is trying to send a charge. No ignition advance there, I'm afraid.
I suppose the reluctor that rotates past the crank sensor could be modified to advance timing a few degeees, but I doubt that you'd want to go that route if it can be done with a computer.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 02-12-2017, 09:55 PM   #3
65standard
65standard's Avatar
Thanks for the info. That's what I was thinking but not sure about.
Old 02-13-2017, 08:11 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
You would need a tune.
Even if you did advance/retard the reluctor at the crank, you would get a cam/crank correlation fault code. You could then perform the cam/crank relearn with a scan too, which would get you back to square one.
95 S_Trucker is offline   Reply With Quote
